Latest: Kifi69
Overall: 17183
Online Now [757]:
Visitors: 756
Today: 101598
Total: 143519248
Forums › The Car › 206 Problems › Temperature in the Red from cold.
kiph
PostPosted: Sun Dec 26, 2010 9:40 am Up
When I turned the car on this morning, the temp gauge shot to the top and the STOP light was flashing. Obviously the water is still cold, and the radiator has kicked in. I'm guessing a sensor somewhere has failed. I've a 2001 1.6 16v preplex. Where should I be looking?
Take it it'll be safe to drive until It's sorted?
K
Kip - 2001 - 206 GLX - 1.6 - 16v - 110BHP
elcamino
PostPosted: Sun Dec 26, 2010 9:56 am Up
Take it it'll be safe to drive until It's sorted?]
K
If the temp gauge went to the top before the engine gets warm this is a sensor fault.but its better to fix it before driving.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
Antknee
PostPosted: Sun Dec 26, 2010 11:03 am Up
this happened to me last week, on my way to work, while i was late... lol :/
i just disconnected the battery like you do
hasnt come back since but has done it before in the past, think its my temp sensor, going to fix mine in new year when i can do it without my hands falling off lol
kiph
PostPosted: Sun Dec 26, 2010 11:40 am Up
Okay well did a little diagnostics check and an no error codes are logged, which I suppose is good... and after running for about 5 mins the temperature level dropped to what it should be and the 'STOP' stopped flashing.
Looking in Haynes there appears to be two sensors that it could possibly be..
The 'Engine Management System Coolant Temperature Sensor' - which is fitted to the coolant outlet housing on the left hand end of the cyclinder head with a green connector
or
The 'Coolant Temperature Gauge Sensor' - which is on the left hand end of the cylinder head, with a blue connector.
Any idea which one it could be?!
Help!
K
elcamino
PostPosted: Sun Dec 26, 2010 12:03 pm Up
I think first one's controlling the cooling fan operation.second one moves the pointer. Smile
PostPosted: Sun Dec 26, 2010 12:37 pm Up
Does the radiator fan come on?
kiph
PostPosted: Sun Dec 26, 2010 2:17 pm Up
Yes when the temperature is high the radiator fan comes on.
