Online Now [579]:
Visitors: 578
Today: 76728
Total: 105803347
Forums › The Car › 206 Problems › Water in passenger footwell
Mike
PostPosted: Sun Dec 26, 2010 1:16 pm Up
Trade Rating: +28
Yep, another one of 'these' threads!
Lifted my mats out today and noticed a fair amount of water in the passenger footwell under the mat. Not sure how long it's been there for as the mats have been in a while.
It's in the centre of the footwell only and the front, back and sides of the carpet feel bone dry!
The water itself isn't greasy or dirty as such, just smells musky.
I'm fairly sure it's not coming from the heater matrix as I've not needed to top the water up, it's spot on the same level as it was ages ago. Where abouts are the pipes that tend to leak so I can check?
It's not coming from the map reading light as it's bone dry.
It's not coming from the door membrane as I've had the door open and put the hosepipe on the outside and 99% of the water goes down the door with a tiny bit coming out the bottom of the door through the drainage holes to the outside.
How easy is the carpet to take up in the footwells as it was gong dark by the time I'd finished?
Cheers.
sherman_2009
PostPosted: Sun Dec 26, 2010 1:21 pm Up
Come be coming from the roof by the arail.
Have a 206 LX 1.4
Mike
PostPosted: Sun Dec 26, 2010 1:22 pm Up
Trade Rating: +28
Checked by the map reading light, puled roof lining back etc and its bone dry :S
Mike
PostPosted: Mon Dec 27, 2010 4:39 am Up
Trade Rating: +28
*Bump*
PostPosted: Mon Dec 27, 2010 4:41 am Up
Have you had passengers in?
Mike
Trade Rating: +28
Not in a long time no, it's also under the at rather than on top :/
PostPosted: Mon Dec 27, 2010 4:44 am Up
Whats the glovebox like? Everything dry in there? Check the back (not the back of the inside, the outer back - Undernearth the dash) of the glovebox as well. Smile
PostPosted: Mon Dec 27, 2010 4:57 am Up
drips in from the top of the door seal and saturates the centre of the footwell carpet Sad
replace the door seal with a new one and mop up as much water as possible then leave the car running for half hour with the heater on full pointing at the footwell and it will dry it out Smile
Ben.M
PostPosted: Mon Dec 27, 2010 5:10 am Up
This has happened to me once or twice and could never find where its from as everywhere else is bone dry but I dont see how it can come from the door as it tends to be up the top right hand corner of the mat :/
Ben.M
Mike
PostPosted: Mon Dec 27, 2010 5:43 am Up
Trade Rating: +28
Cheers guys, yeah everywhere else is bone dry.
Will have a look at the door seal, cheers Smile
PostPosted: Mon Dec 27, 2010 7:32 am Up
it drips down from where the top of the door seals to the roof on my grey one got my mate to blast it with the steam cleaner while i sat inside Razz
Davo_Pug
PostPosted: Wed Dec 29, 2010 4:35 am Up
I had this once before......never found the problem out....tried mopping up as much as i could and layed newspaper out the previous night to see if i could see where it would soak up on the paper first to give me a rough idea where it was coming from....but it never happened again?!?!i think this is a genuine 206 mystery!!!1
Davo_
dj71
PostPosted: Wed Dec 29, 2010 3:56 pm Up
you could try the heater matrix which is located to the rite of the passenger footwell at the fan area, iv had a couple of peugeot's with a leaking matrix.
dj71
chris001
PostPosted: Thu Dec 30, 2010 3:29 pm Up
Hi Mike,
I have the exact same problem with mine (1.6 2000 GLX). Looks like mine is coming from right hand side of the passanger footwell, the matts are wet. I thought it could be the heater matrix too but my fluids don't seem to be going down? My washers are out of water so wanted to elimiate this by leaving it and seeing if the leak keeps on.
Did you ever find out what was causing yours?
I think I'll also check my arial as suggested above. Its coming from the centre console on mine so dont think it could be the door seals.
Chris
Chris
