Latest: tbafonso
Overall: 17130
Online Now [53]:
Visitors: 52
Today: 39233
Total: 104509288
Forums › The Car › 206 Problems › 206 gti and non gti clutch pedals??
PostPosted: Mon Dec 27, 2010 4:30 am Up
will the gti clutch pedal be the same as the 1.4 clutch pedal?
i know ones cable and the other hydraulic but was wondering if whatever attaches them is the same so i can stick a gti one on my 1.4
PostPosted: Mon Dec 27, 2010 5:32 am Up
Should be the same yes...there's only one way to find out though.
PostPosted: Mon Dec 27, 2010 5:36 am Up
lol cheers will take a chance and get them if they are cheap enough and look right
its confusing because i cant compare them to mine as i have auto atm and am converting it over Wink
johnk
PostPosted: Mon Dec 27, 2010 7:59 am Up
if your fitting a gti gearbox you need the whole pedal box from a gti as it has a hole that matches the bulkhead where the slave cylinder goes through to the pedal.
1.4 pedal box has a bit of metal at an angle going through the bulk head for the clutch cable so you cant attatch the slave cylinder.
Old info post count 1500
johnk
PostPosted: Mon Dec 27, 2010 8:07 am Up
This is the engine bay where the slave cylinder attatches to and as you can see the 1.4 manual pedal box has this in the way.
PostPosted: Mon Dec 27, 2010 12:23 pm Up
cheers for the help john Smile
im not actually fitting a gti box im fitting a manual 8valve tu box to my 1.4 engine and binning the auto box as its gone bang Smile
just im going to get some bits of a gti tommorow and if the pedals were the same id buy them too while i was there Smile
