Posted: Mon Dec 27, 2010 12:32 am |
got the 1.4 hdi 03 plate and it just doesnt get hot, it runs at around 70-75 degress which only gives you warm air inside the car, not just cause of the snow either, its been the same every day since we've had it, is this normal and is there a mod for this so we can have hot heaters.
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Mon Dec 27, 2010 3:06 am |
Hmmm... Mine only ever runs as high as 70.. Yet still gives hot air.
U may need to change the heater matrix mate. Some1 else will be able to confirm the reason for u however
Posted: Mon Dec 27, 2010 3:13 am |
Diesels do take an eternity to warm up...less energy from the fuel is wasted by turning it into heat which is why they are more efficient than petrol engines. The heaters never gets as toasty hot as petrol engine do.
Posted: Mon Dec 27, 2010 5:47 am |
Edward wrote: |
Diesels do take an eternity to warm up...less energy from the fuel is wasted by turning it into heat which is why they are more efficient than petrol engines. The heaters never gets as toasty hot as petrol engine do. |
fair point, but i've run a few diesel's and petrol cars and i've never really noticed a major difference with them,
| Mark
Posted: Mon Dec 27, 2010 5:49 am |
tomd0801754 wrote: |
Hmmm... Mine only ever runs as high as 70.. Yet still gives hot air. |
does yours ever run hotter than 70,
| Mark
Posted: Mon Dec 27, 2010 5:50 am |
wardie_206 wrote: |
U may need to change the heater matrix mate. Some1 else will be able to confirm the reason for u however |
it's not leaking, do you think its blocked or some thing.
| Mark
Posted: Mon Dec 27, 2010 11:28 am |
any one???
| Mark
Posted: Mon Dec 27, 2010 11:58 am |
Trade Rating: +37
have you tried changing from fresh air to recirculating the air? i did this last month when it got real cold and i now get hot air once again
Posted: Mon Dec 27, 2010 1:36 pm |
yeah i do use that, i also find that windscreen does not clear while on recircultion mode, so have to turn back, but makes no differnece to the heat.
| Mark
