Latest: tbafonso
Overall: 17130
Online Now [313]:
Visitors: 313
Today: 11085
Total: 104279477
Forums › The Car › 206 Problems › 1.4 HDi Starts but runs lumpy! Glow plugs?
CRWCars
PostPosted: Wed Dec 22, 2010 6:52 pm Up
I posted on this topic a while ago. The car always starts but if its first thing in the morning or a cold engine, the engine runs lumpy for the first few seconds, kicks out a little smoke and then settles to a steady smooth idle. My query is how reliant is the HDi engine on its glow plugs? Some say these engines will start without them, but as it is continually cold at the moment are the glow plugs meant to improve the start. Does the ecu determine whether the glow plugs kick in on a cold start? Some details on how this works would be interesting! Thanks!
CRW
apjs87
PostPosted: Thu Dec 23, 2010 3:18 am Up
The car starting fine tells me the glow plugs are fine. The lumpy bit afterwards is the ECU sorting out what revs the car needs to settle it into the smooth idle u talk about. All is normal. Does the same with mine
No longer a 206 owner
Astra H sxi. 1.7Cdti
panason1c
PostPosted: Thu Dec 23, 2010 3:29 am Up
My 1.4hdi starts almost instantly in temps currently -5 degrees with absolutely no lumpiness or misfire.........It definately is not normal to have an initial misfire/lumpiness on startup.
1.4 hdi, 206, Year..2003, 100,000 miles
Mercedes, ML270CDI, 2002, 200,000 miles
BMW K1200RS
panason1c
PostPosted: Thu Dec 23, 2010 3:45 am Up
HDI (and similar CDI, etc) engines dont need glowplugs to actually start, the g'plugs are fitted mainly to comply with emission controls by reducing the amount of smoke on startup, which contributes towards a lower Co2 rating (which is why my 1.4hdi is only £30 per year road tax)......
BMW K1200RS
apjs87
PostPosted: Thu Dec 23, 2010 4:07 am Up
If it's anything like mine which I think it is, there is no misfire, just a slight drop in revs then back to normal. Is that not what is meant by lumpiness?
panason1c
PostPosted: Thu Dec 23, 2010 4:13 am Up
No............'lumpiness' is... 'uneven running'
BMW K1200RS
twed207
PostPosted: Thu Dec 23, 2010 4:43 am Up
my sisters does this... it will start but once started it's very clatery and lumpy for 5-10 secs. no matter how cold. Confused
206 2.0HDi
My 207 WIP
Turbo Diesel Owners Club UK
L200 thread
mjsroofing
PostPosted: Thu Dec 23, 2010 7:16 am Up
it sounds the same as faulty heater plugs, could it just be that one cylinder has slightly lower compression than the other, but once warm it sorts it self out, i think you would have to do a few test to fing out what this is
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
MrrNoName
PostPosted: Thu Dec 23, 2010 7:21 am Up
what colour is the smoke that comes out on startup?
if its grey/blue it could be that you have a leaky valve letting oil drip into the combustion chamber when the car is left to rest. when its started, it fires up quickly because the plugs are working fine, but then runs roughly for a few seconds because its burning the oil off in one of the cyliners. had this on a 1.9 Skoda once. car ran for years like it though.
if your start it and let the idle smooth out, then stop it and start it again does it run rough the second time? if not it could be because the oil has burnt off Razz
CRWCars
PostPosted: Thu Dec 23, 2010 7:32 am Up
Have had injector readings checked and it has been suggested that one injector is being compensated for, so may go down that route. Still suspect glowplugs are problematic. Once car has been started, all subsequent re-starts are smooth. Had thought of air leak on fuel lines, but car still started after being left for 5 days.
CRW
mjsroofing
PostPosted: Thu Dec 23, 2010 11:33 am Up
air leak mainly causes it to take a while to start but then run fine, it does sound glow plugs, again an injector would do it on every start i would of thought
Mark
continentalgt
PostPosted: Thu Dec 23, 2010 2:07 pm Up
Very doubtful its the glow plugs, I also run a petrol car and the 1.4 hdi is my first ever diesel so I often forget to check the glow plug light and take the key straight through to start up. Even at sub zero temperatures it starts immediately and runs smoothly from start.
206 1.4hdi & 1.8 Astra Elegance
mjsroofing
PostPosted: Thu Dec 23, 2010 3:26 pm Up
yeah the one i got is the same, if you look fo rit when its really cold you'll just see the light for half a second, i dont think they need much to start them, but if one dont work surely it would make a difference????
many people on here have said that the hdi's dont need heater plugs, but i'm thinking thats fine if they all work or none of them work, but if only one is not working could it make i difference, ?????
any one think the same.
Mark
continentalgt
PostPosted: Fri Dec 24, 2010 3:00 pm Up
I guess it might depend on how long the glow plugs stay on, I assume maybe incorrectly that they turn off as soon as the engine fires up.
mjsroofing
PostPosted: Fri Dec 24, 2010 3:02 pm Up
i know on the older diesel cars they stay on with the relay, wether engine running or not
Mark
