Online Now [188]:
Visitors: 187
Today: 39692
Total: 142945800
Forums › The Car › 206 Problems › yellow engine light
yellow engine light
hampshire1
PostPosted: Tue Dec 28, 2010 1:30 pm Up
girlfriend has 1.1 2004 206. yellow engine light is on but car is running perfect. the oil was very low (off the dip stick)!. topped up with oil now showing full. would this have caused the engine management light to come on? if so hoew can i get rid of the light now? cheers
206 1.4 hdi 2003
Needs a code scan, your just guessing unless you have the codes read Wink
PostPosted: Tue Dec 28, 2010 1:31 pm Up
Needs a fault code scan.
[/end thread]
hampshire1
PostPosted: Tue Dec 28, 2010 1:34 pm Up
would the aa be able to read the code if she called them out?
206 1.4 hdi 2003
PostPosted: Tue Dec 28, 2010 1:35 pm Up
Yes
PostPosted: Tue Dec 28, 2010 1:36 pm Up
Yes, they should be able to but they wont be to happy unless the cars actually broken down Laughing
hampshire1
PostPosted: Tue Dec 28, 2010 1:40 pm Up
do you know if low oil sets the engine manegement light off?
206 1.4 hdi 2003
PostPosted: Tue Dec 28, 2010 1:41 pm Up
Shouldnt do, who knows what codes the ecu has stored Laughing
Then again the oil level gauge on the dash at start up gives plenty of clues to the engine oil level Wink
PostPosted: Tue Dec 28, 2010 1:58 pm Up
why to call AA to read you the codes,while your GF car is running perfect as you said,the AA for help on the road when your car is broken down.
So take it to the garage or the dealer instead of guessing,because such light on the dash can be cause by hundreds of things,and only diagnostic software can tell you what it's for sure,good luck.
PostPosted: Tue Dec 28, 2010 2:02 pm Up
They have paid the fee for the AA already, so why pay again? Wink
PostPosted: Fri Dec 31, 2010 7:10 am Up
I agree!
