Online Now [287]:
Visitors: 286
Today: 8250
Total: 142276771
Forums › The Car › 206 Problems › Cooling Fan Problems
Kevee
PostPosted: Thu Jul 28, 2011 5:46 am Up
Hello,
When our 206 (03 plate 1.4) starts to get hot you can hear a cooling fan kick in, however when looking at the front of the car the fan you can see through the front grille is not moving. It appears to take a long while for the car too cool back down to 90 degrees.
I read that these cars have 2 fan speeds and that when the needle is approaching the red it puts the fans on full. I also read that the vehicle has 2 fans, my query is that when the low speed is triggered shouldn't both fans be switched on?
Thanks,
Kevin
Peugeot 206 1.4LX Auto
panzer360gti
PostPosted: Thu Jul 28, 2011 6:45 am Up
How hot is it getting?
Peugeot 206 GTI 137 2.0
Kevee
PostPosted: Thu Jul 28, 2011 6:49 am Up
It is getting to the next mark after the 90.
meady
PostPosted: Thu Jul 28, 2011 6:58 am Up
Trade Rating: +45
My gti only has 1 fan :s
TEAM - I HATE FACEBOOK Smile
PostPosted: Thu Jul 28, 2011 7:05 am Up
the slow fan normally comes on around 93, to take it back to 90. fast fan comes on when closer to the red.
Kevee
PostPosted: Thu Jul 28, 2011 7:21 am Up
Is there any way to make the fan cut in closer to the 90 mark? I imagine the next line on the dial must represent 95 which is a little hotter than when should be cutting in.
panzer360gti
PostPosted: Thu Jul 28, 2011 7:29 am Up
Unless your needle starts hitting red, I wouldnt panic, its quite normal to run at 90 plus.
PostPosted: Thu Jul 28, 2011 7:32 am Up
Probably not. I would think thats in the code of the ECU on what temp the fan cuts in. I didnt say exactly 93 so there or there about. As long as it takes it back down to 90ish it should be fine.
But you say that you cant even see the fan turning so does the low speed fan not work at all? might need to check relays/connections/resistor if so.
Kevee
PostPosted: Thu Jul 28, 2011 7:53 am Up
I can hear a fan whiring sound but the one you can see through the front grille is not moving.
I assume there are 2 fans?
scousemouse
PostPosted: Thu Jul 28, 2011 11:56 am Up
possibly the fan motor is spinning but not turning the fan blades .
with the ignition off see if you can feel resistance when turning the fan blades with a finger if no resistance the blades are disconnected from the motor
if you can\'t fix it with a hammer your problem\'s electrical
