Posted: Sat Jan 01, 2011 3:45 pm |
wondered if it would fit? also whats the gearing if any one knows on the 180's i want more top end from my gti
many thanks
Posted: Sat Jan 01, 2011 4:14 pm |
IIRC the 180's have longer gearing but not by much, unless your gearbox is knackered i would bother fitting one
More than likely the sensors are different, but seeding your box is also hydraulic there should be no real problem in fitting
| Team Impossible Possible
Posted: Sat Jan 01, 2011 4:15 pm |
The top end would be over 120mph or something? Do you really need this or are you planning on taking your pug on track?!
Posted: Sat Jan 01, 2011 4:16 pm |
DJ- wrote: |
The top end would be over 120mph or something? Do you really need this or are you planning on taking your pug on track?! |
Even then i wouldnt bother, just change the final drive ratios to see a difference (top end or acceleration)
Posted: Sat Jan 01, 2011 4:21 pm |
it would fit but the 180 is cable operaterd gear linkage so you would need that too
Posted: Sat Jan 01, 2011 5:26 pm |
thanks guys !
would it be better just to change the final drive then?
only reason is i do alot of long journeys and city
raves/work lol
Posted: Sat Jan 01, 2011 5:28 pm |
A GTi 180 gearbox is not a step in the right direction. A 206 GTi 138 gearbox has perfect ratios for 130mph at 6500 rpm.
Shorter gearing is what you need.
Posted: Sat Jan 01, 2011 5:34 pm |
yeah but thats the limiter !! just to get 130 @6500rpm i want it to do 120@4500rmp so its chilled not screaming
Posted: Sat Jan 01, 2011 5:36 pm |
That will blunt your acceleration though. Will the car have enough power at 4500 rpm to do 120mph? Do you need to cruise at 120mph?
Posted: Sat Jan 01, 2011 5:45 pm |
hence the question . i would like the last gear to rev less but go further
i have a gti 16v 138 bhp
