Online Now [89]:
Visitors: 89
Today: 5189
Total: 105013636
Forums › The Car › 206 Problems › top mount
top mount
mjsroofing
PostPosted: Sun Jan 02, 2011 11:41 am Up
its started to make a horrid noise when turning the wheel, has started just after the snow not sure if that is related. i'm going to talk it off and inspect it when i have time, are these repairable or a repacement part. i was thinking of just greasing it up.
Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k.
PostPosted: Sun Jan 02, 2011 11:43 am Up
Cheap enough to replace with new tbh, rather than p**sing about attempting to fix.
T_bandery
Needs to be replaced, they are £13 for the pair from Bridgend motor factors Wink
mjsroofing
PostPosted: Sun Jan 02, 2011 11:47 am Up
cheers for that i'll pick up a pair tuesday, dont like using bridgend motor factors as most of their parts are cheap and nasty, i use gmf most of the time
Mark
T_bandery
PostPosted: Sun Jan 02, 2011 12:03 pm Up
Didn't know there was one in bridgend... where by is it?
mjsroofing
PostPosted: Sun Jan 02, 2011 12:08 pm Up
GMF is on Bridgend ind est, north rd. just up the road from my place.
they arent always as cheap but they have more stores and can normaly get thing in teh same day, good service.
Mark
tofy92
PostPosted: Sun Jan 02, 2011 1:46 pm Up
London Area Rep - tofy92
do u mean gsf (german swedish french)
mjsroofing
PostPosted: Sun Jan 02, 2011 1:53 pm Up
no, as i said GMF. genaral motor factors.
Mark
PostPosted: Sun Jan 02, 2011 1:55 pm Up
Just order some top mounts and bearings from Euro Car Parts. They aren't expenisve. I'd also order some new nuts and bolts for the hub to ball joint and hub to damper connections.
mjsroofing
PostPosted: Sun Jan 02, 2011 2:01 pm Up
hub to ball joint shoul be ok, i only had them off a little while ago to change the wishbones, damper connections??????? i'm guessing we call things different here ????
Mark
PostPosted: Mon Jan 03, 2011 3:07 am Up
All the nuts are of the nyloc type so should be replaced. Where the damper attaches to the hub there is also a nut and bolt. I'd replace them too.
PostPosted: Mon Jan 03, 2011 4:41 am Up
What He Said
Nyloc nuts can only safely be used ONCE! Wink
TomMessenger
PostPosted: Mon Jan 03, 2011 4:55 am Up
I bought one from GSF and it was £50 per side! I found mine had completely shattered from rust, not good!
www.me-strings.co.uk - Day Job
www.tommessengerphoto.com - Occasional Job
tommessengerphoto.com/page7.htm - Fishy Stuff
PostPosted: Mon Jan 03, 2011 4:58 am Up
Peugeot / Citroen part number 5035 27 Bearing £26.10
The actual top mount bracket are £50.58 each from Peugeot / Citroen
PostPosted: Mon Jan 03, 2011 5:33 am Up
cheap ebay top mount bearing won't last long.
mine broken within 2 months Laughing
