Posted: Sun Jan 02, 2011 12:41 pm |
its started to make a horrid noise when turning the wheel, has started just after the snow not sure if that is related. i'm going to talk it off and inspect it when i have time, are these repairable or a repacement part. i was thinking of just greasing it up.
| Mark
03 206 1.4 hdi 3 door 187k
02 transit 100 280 196k
04 renault Laguna 80k
09 transit 115 300 43k. | |
Posted: Sun Jan 02, 2011 12:43 pm |
Cheap enough to replace with new tbh, rather than p**sing about attempting to fix.
Needs to be replaced, they are £13 for the pair from Bridgend motor factors
Posted: Sun Jan 02, 2011 12:47 pm |
cheers for that i'll pick up a pair tuesday, dont like using bridgend motor factors as most of their parts are cheap and nasty, i use gmf most of the time
| Mark
Posted: Sun Jan 02, 2011 1:03 pm |
mjsroofing wrote: |
cheers for that i'll pick up a pair tuesday, dont like using bridgend motor factors as most of their parts are cheap and nasty, i use gmf most of the time |
Didn't know there was one in bridgend... where by is it?
Posted: Sun Jan 02, 2011 1:08 pm |
T_bandery wrote: |
mjsroofing wrote: |
Didn't know there was one in bridgend... where by is it? |
GMF is on Bridgend ind est, north rd. just up the road from my place.
they arent always as cheap but they have more stores and can normaly get thing in teh same day, good service.
| Mark
Posted: Sun Jan 02, 2011 2:46 pm |
do u mean gsf (german swedish french)
Posted: Sun Jan 02, 2011 2:53 pm |
no, as i said GMF. genaral motor factors.
| Mark
Posted: Sun Jan 02, 2011 2:55 pm |
Just order some top mounts and bearings from Euro Car Parts. They aren't expenisve. I'd also order some new nuts and bolts for the hub to ball joint and hub to damper connections.
Posted: Sun Jan 02, 2011 3:01 pm |
hub to ball joint shoul be ok, i only had them off a little while ago to change the wishbones, damper connections??????? i'm guessing we call things different here ????
| Mark
Posted: Mon Jan 03, 2011 4:07 am |
All the nuts are of the nyloc type so should be replaced. Where the damper attaches to the hub there is also a nut and bolt. I'd replace them too.
Posted: Mon Jan 03, 2011 5:41 am |
Edward wrote: |
All the nuts are of the nyloc type so should be replaced. |
Nyloc nuts can only safely be used ONCE!
Posted: Mon Jan 03, 2011 5:55 am |
I bought one from GSF and it was £50 per side! I found mine had completely shattered from rust, not good!
Posted: Mon Jan 03, 2011 5:58 am |
Peugeot / Citroen part number 5035 27 Bearing £26.10
The actual top mount bracket are £50.58 each from Peugeot / Citroen
Posted: Mon Jan 03, 2011 6:33 am |
cheap ebay top mount bearing won't last long.
mine broken within 2 months
