Posted: Tue Jan 04, 2011 1:40 pm |
I have a 1.4 1999 206. It has done 70 000 miles. I recently had it serviced as the cars revs were fluctuating when slowing down that it caused it to cut out. Prior to having it serviced i had a new clutch. The cutting out has almost stopped and now the car is really juddering when stationary and even when driving but is not as bad when i use lower gears. Also it is using LOTS of petrol and does not have much power.
I took it to a garage and had the coil changed - did not make a difference so they didnt bother changing them. The dodgy guy at the garage said its the valves.... and will cost hundreds to fix. But im not sure this is right.Can anybody help???
Posted: Tue Jan 04, 2011 1:56 pm |
Is the EML on?
You tried cleaning the Idle Control valve [also called the stepper motor]
Are Bosch spark plugs fitted?
Did the juddering start before or after the clutch change. Or was it since the service?
Posted: Tue Jan 04, 2011 2:10 pm |
i have the same fluctuating revs problem when the car was at a warm temperature not when it was freezing cold, i changed the oil to a thinner oil but it didnt help i heard it was something to do with the hydraulics but im not sure.
| 206gti sp just need advice | |
Posted: Tue Jan 04, 2011 5:25 pm |
I dont know what the EML is.
I havent got a clue about cars what so ever!! and after the clutch change but not straight away, but there wasn't a problem before!
How would i clean the valve?
Posted: Tue Jan 04, 2011 5:26 pm |
EML= Engine Management Light
spike_202 wrote: |
My Powerflow is quite loud but then again it's on ITBs and has a decat. |
Audi Sport  | |
Posted: Tue Jan 04, 2011 5:34 pm |
It comes on now and again i think, when it stalls x
Posted: Tue Jan 04, 2011 7:33 pm |
can you get someone you know to take it of and give it a clean inside?
Posted: Wed Jan 05, 2011 7:26 am |
As in the PM
Quote:: |
Hi,
The EML is the engine management light, the little orange light in the top right of your dials.
How to clean the idle control valve - 206info.co.uk/Forums/v.../t=72.html
Lee |
