Online Now [431]:
Visitors: 430
Today: 89465
Total: 144909676
Forums › The Car › 206 Problems › Sounds like water coming from the footwell?
Jody.V
PostPosted: Wed Jan 05, 2011 9:22 am Up
Whenever I start the car, and also when I pull away quickly it sounds like water is sloshing about, coming from the passenger footwell. Anyone got any ideas? Cheers Smile
PostPosted: Wed Jan 05, 2011 9:35 am Up
Heater matrix most probably. Are you losing any of your coolant?
Jody.V
PostPosted: Wed Jan 05, 2011 10:12 am Up
Not that I've noticed :S
Andy180+
PostPosted: Wed Jan 05, 2011 4:04 pm Up
possible the sill drain holes are blocked and as you set off water inside is sloshing about Wink clean out the holes and jack car up so they drain
