Posted: Wed Jan 05, 2011 9:09 am |
my handbrake light is constantly on it works fine just the light stays on any help?
thnks ben
Posted: Wed Jan 05, 2011 9:15 am |
your brake fluid is proberly dangeriously low
Posted: Wed Jan 05, 2011 9:31 am |
yeah that happens when brake fluid needs topping up best check it asap
| New car 2011 / Thoruim grey , 207 1.4 Vti 16v Sport 95bhp , tinted rear windows.
Old car 2000/ 206 2.0 hdi. | |
Posted: Wed Jan 05, 2011 10:38 am |
either that or check the cable that connects the the handbrake switch under your handbrake
| Clarion VZ409E 7 inch DVD motorised screen
Sony XMZ-R604 440 watts Channel Amplifier
Vibe Slick 12" 1200 watt Subwoofer
Pioneer TS-A6903i 6 x 9 3-way 350 watts
Raceland 4-2-1 Stainless Steel Manifold
Remapped Ecu
Wolfrace Street Hustle 17"
Click For Da WIP! 206info.co.uk/Garage/m...d=336.html | |
Posted: Wed Jan 05, 2011 11:09 am |
cheers everyone i must of knocked it the otherday it was the swtich under the handbrake. i ran out there with some brake fluid n it was full so i double checked in side n it was the switch thanks for the help every one
Posted: Wed Jan 05, 2011 11:34 am |
I'd check the brake pads as well. the light comes on when they're low.
| Hi Mikey
Posted: Wed Jan 05, 2011 2:32 pm |
If the hand brake light is on with no STOP light flashing on dash and no beep its the switch stuck under hand brake.
| el camino. "Whether you think you can or you think you can't, you're right" Henry Ford. | |
Posted: Wed Jan 05, 2011 3:02 pm |
just done my brakes like 3 weeks ago was the switch under the handbrake thanks for help
Posted: Thu Jan 06, 2011 3:43 am |
elcamino wrote: |
If the hand brake light is on with no STOP light flashing on dash and no beep its the switch stuck under hand brake. |
Correct.
Unless the STOP warning light is on at the same time as the (!) its always the handbrake switch.
If you get STOP & (!) then check the brake fluid
Posted: Mon Jan 17, 2011 6:36 am |
Ive got this problem with the STOP light flashing, (beeps sometimes to) and the (!) light at the same time. I have checked brake fluid and thats fine. It is fairly intermittent in terms of when it flashes, could go a long time with nothing or a few minutes. Will always happen though. How do you check the handbrake switch? or what else could it be? So annoying! And every genius who gets in your car likes to point out to you that there's a light flashing on your display as if you havent noticed!!!
Any help mucha appreciated!
Posted: Mon Jan 17, 2011 6:43 am |
jakehorton wrote: |
Ive got this problem with the STOP light flashing, (beeps sometimes to) and the (!) light at the same time |
Its a brake fluid low issue OR the switch in the brake fluid bottle cap / connection
Posted: Fri Jan 27, 2012 4:00 am |
Trade Rating: +20
I've had this happen to me, I thought it was the hand brake at first.
The hand brake light flickered on and off and beeped without the stop light flashing.
Day after it happened again, but the text "break fluid levels low" came up on the dash with the flashing red STOP and hand brake light.
I've had NO problems at all apart from 3 weeks ago where it happened the same way.
I topped up the brake fluid, must admit it took about 30ml/40ml of fluid.
It's now happening again??
You think it could be a faulty fluid pot or connection?
Cheers chaps
