Latest: tbafonso
Overall: 17130
Online Now [116]:
Visitors: 115
Today: 29206
Total: 104297538
Forums › The Car › 206 Problems › ECU/engine misfire
ECU/engine misfire
Go to page Previous  1, 2, 3
Twincam007
PostPosted: Tue Mar 08, 2011 7:30 am Up
Hi seeen this as I was doing some research for my own car. 1999 Gt1 138.
minimopar.knizefamily....nairadjust
My idle is currently around 600rpm and is really lumpy in the mornings.Its been happening for about a month now. I laso cleaned out the idle control valve, map sensor, throttle position sensor, throttle in general with brake cleaner, and had no change. Bought a new coil pack from Euro (Valeo), and peugeot plugs, and this seemed to have made the idle even more erratic. I may try changing my oil next as well.
Will be trying the Minimum Air Adjustment thingy this weekend.
Twincam007
Davels
PostPosted: Tue Mar 08, 2011 7:48 am Up
Hmm sounds interesting but also like the most complicated process ever Laughing I dont know where hald the stuff mentioned is located for a start Sad
EDIT having looked at it it appears the AIS is the Idle control valve.
Davels
PostPosted: Thu Mar 10, 2011 2:06 pm Up
New air temp sensor fitted tonight. Engine was warm so can't tell if it has made any difference yet. Car seemed to be idling lower at just under 800rpm rather than just over but that could be weather conditions or my mind playing tricks. Don't really know if it would be effected by a sensor change anyway. I'll be able to tell tomoz morning hopefully from cold
Davels
PostPosted: Mon Mar 28, 2011 11:30 am Up
This is really getting to me now, I have changed everything that people have suggested, coil, sparks, map sensor, idle control valve etc, cost a bit of money for stuff that wasn't the cause but a least it ruled those parts out Laughing . The car has been fully serviced and valve lifter treatment added to no effect. It's been plugged into a diagnostic machine while running from cold and no faults are being read whatsoever despite misfiring and juddering worse than ever while plugged in.
Which is a problem, as it seems to be getting worse.
It's been given a clean bill of health mechanically and the only thing they mechanics can suggest is a faulty ECU not telling the injectors to pump enough fuel in when cold. To fix that we are talking mega money by the looks of things, just after i've had to fork out for a cam belt change it's just no possible. My yearly bonus can only go so far lol.
It seems to chug a bit at idle now when cold, but not cold enough for the juddering to start if that makes sense
Can anyone suggest something that I may have missed? I'm at my wits end...wherever that may be...
Twincam007
PostPosted: Tue Mar 29, 2011 2:04 am Up
oxygen/lamda sensor? - apparently they don't always show fault codes but doesnt mean they on their way out. Phew, that would be almost every sensor changed.
Twincam007
Quarmbo
PostPosted: Tue Mar 29, 2011 3:37 am Up
Injectors?
Ford SportGay-A
Davels
PostPosted: Tue Mar 29, 2011 5:24 am Up
No, injectors are fine so to was the O2 sensor but that would be harder to 100% test.
Page 3 of 3
