Online Now [116]:
Visitors: 115
Today: 47191
Total: 127798026
Forums › The Car › 206 Problems › Central Locking Issue :(
A18NHH
PostPosted: Sat Jan 08, 2011 5:34 am Up
Hi,
yesterday i opened my car with my key fine, did some shopping and upon return the key fob didnt work so i had to use the key in the lock...
When i got home and went out next i got the spare key, assuming the battery had gone in the original key, the spare key worked to unlock it but that has now stopped working.
i find it hard to believe both key have stopped working in the same day and wonder if it could be something else?
This morning neither key works Sad
Wahoo!
PostPosted: Sat Jan 08, 2011 5:38 am Up
take the key to a jewellers and get them to test the batt or just simply change it,
it could be that the main one has gone flat and the spare key just sitting there has done too. never know
good luck.
A18NHH
PostPosted: Sat Jan 08, 2011 12:40 pm Up
The keys battery is okay apparently.
Could it be a fuse? or the reciever is buggered?
Wahoo!
elcamino
PostPosted: Sat Jan 08, 2011 1:52 pm Up
Is it working by locking/unlocking from inside?
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
A18NHH
PostPosted: Sat Jan 08, 2011 2:46 pm Up
with the button? No the buttons don't work what so ever.
If i push the pin down on the doors inside then it only locks the one door, not both driver and passenger side
It's really annoying now... Sad
Wahoo!
A18NHH
PostPosted: Sun Jan 09, 2011 10:32 am Up
anyone?
Wahoo!
PostPosted: Sun Jan 09, 2011 11:57 am Up
Reboot the BSI unit.
elcamino
PostPosted: Sun Jan 09, 2011 1:16 pm Up
If rebooting BSI didnt help check the wiring inside drivers door mate.
PostPosted: Sun Jan 09, 2011 2:15 pm Up
maybe the master central door locking "brain" is missed up,check the driver door,if it work,then check the passenger door,it should close all doors too
