Online Now [296]:
Visitors: 295
Today: 18618
Total: 106064467
Forums › The Car › 206 Talk › New Speedo Mileage Change
davieboy86
PostPosted: Sat Jan 08, 2011 9:49 am Up
Hey guys well ive just managed to find myself a replacement speedo unit for the one i broke a few weeks ago. While i was changing the dials over i broke the LCD ribbon cable for the milage screen.
After a few false starts i've managed to get a fully working unit, the only problem is that the milage showing on the screen is set at 72000 ish miles and the car was only at 42000 ( 39000 at the last official recorded service).
I knew prior about the issue of putting in new clocks with a higher milage than the car itself but after doing some research there are companies out there that can correct mistaken dials. these all appear to be real legit companies like dash doctor and cluster repairs UK. However it appears they are using something similar to peugeot planet (or whatever the program is called).
Now finally to my questions lol,
1. does anyone have any knowledge / experiance in this area?
2. Is anyone actually capable of doing this for less than the £50 i was quoted by these companies?
Thanks for any help or direction guys.
PostPosted: Sat Jan 08, 2011 9:54 am Up
You can't do it with Peugeot Planet, they use software and hardware only legally available to licensed companies. They use like Tachpro which is like £400 for clones, never mind the real mccoy.
It will be more than £50.
PostPosted: Sat Jan 08, 2011 10:02 am Up
BBA Reman can correct mileage on clocks for about £50 I think. They normally just need the last MOT certificate to prove the mileage.
PostPosted: Sat Jan 08, 2011 10:13 am Up
Danny224 wrote:
I got some new dials which do have a lower mileage then my older ones i thought would change to the higher mileage is there anything i need to do, or will it do it after a certain amount of miles.
Only multiplexed 206's will.
Non plexed will display whatever is in the actual instrument cluster memory.
Dillon
PostPosted: Sat Jan 08, 2011 10:27 am Up
Staff - Dillon
Topics merged as there the same question, put differently.
davieboy86
PostPosted: Sat Jan 08, 2011 10:29 am Up
cheers buddy, ill give them a call, all advice welcome.
PostPosted: Sat Jan 08, 2011 11:27 am Up
I thought that speedo reads what the ECU have in the memo.,right?,or that is wrong??
PostPosted: Sat Jan 08, 2011 11:32 am Up
Rob2859
PostPosted: Sat Jan 08, 2011 11:44 am Up
would be cheaper to buy a cluster with lower miles than your car and sell the others
T_bandery
PostPosted: Sat Jan 08, 2011 11:55 am Up
http://www.gumtree.com/london/86/66734586.html
davieboy86
PostPosted: Sat Jan 08, 2011 2:02 pm Up
Trying to find pre plex dials with under 42000 on the clock has been pretty tricky so far lol, I might give that gumtree ad a call, jut want it done properly not some bodge job if you see what I mean.
MPorter13
PostPosted: Tue Jun 12, 2012 3:40 am Up
ive been told they are a nightmare to do, really fiddly. spoke to a chap that said if anyone quotes your £50 to check to see if their work is warranted as the bsi needs to messed on with, if it goes wrong your car will become a shell, he said its not worth it but he will do it for £250 to cover his own back
MPorter
