Posted: Mon Jan 10, 2011 11:51 am |
About a week ago i posted about my 1.4 8v juddering and stalling on start up and people suggested cleaning my stepper motor so iv cleaned that and it was quite dirty and iv changed my coil pack aswel, but stil no change, just wondering if anyone has any other ideas?
Thanks, Ross
| 2003 lx Aluminium Silver, 16' Nimrods, ph2 Bootstrip, ph2 Rear Lights, K&N Panel Filter, Alpine ida-x200 HU, Alpine Type E Door Speakers, Vibe Sub, Part GTi Interior | |
Posted: Mon Jan 10, 2011 11:59 am |
Next step id take is renewing the sparks
| Renault Clio III RS - Race Car
Former Poverty 206 XS 1.6Turbo Owner  | |
I'd have done that before changing the coil pack, its cheaper
Posted: Mon Jan 10, 2011 12:08 pm |
cheers for that, what are the best spark plugs bosch or NGK?
Posted: Mon Jan 10, 2011 12:12 pm |
Bosch
Coilpacks dont react well to NGK sometimes on 206's
Posted: Mon Jan 10, 2011 1:28 pm |
Clean the Idle Control Valve
| Peugeot 206 1.4LX - Sold
Vokswagen Bora 2.0 - Sold
Seat Leon MK2 2.0 TDI - New
Posted: Mon Jan 10, 2011 1:38 pm |
they are well known for number one injector going down too. does the engine management light come on at all when it judders???
Posted: Mon Jan 10, 2011 1:41 pm |
Danny224 wrote: |
Clean the Idle Control Valve |
He said he cleaned the Stepper Motor (same thing)...
Posted: Mon Jan 10, 2011 1:46 pm |
Could be any of the sensors...map sensor, lambda sensor, throttle position sensor...list is endless.
Posted: Mon Jan 10, 2011 3:00 pm |
Edward wrote: |
Could be any of the sensors...map sensor, lambda sensor, throttle position sensor...list is endless. |
Edward is wright really.
When you say its juddering do you mean its missfiring???
Can you give more info whats it is doing?? because all mechanics will say its hard to say whats the fault is intill you see it in person faulting??
why dont you get the car scaned by garage???
| 206 Gti 180 Cat-camshafts 804's, Cat cams CTPE 002 exhaust vernier pully, RS tuning remap, Cat back janspeed exhaust, K@N Typhoon induction kit- heat wrapped, Exhaust manifold heat wrapped, Goodridge brake flexi's poly bushs in rear lateral arms, blue led speedo convertion, 50mm Eibach sport line springs, ......
180 Doctor
Hemwoods Gti180 / Pug specialist | |
