Posted: Tue Jan 11, 2011 6:28 am |
Hi
Can someone tell me the difference betweent these to part numbers
6429S1
6429P0
They are for the drivers wiper arm which I need to replace.
| | ![](images/spacer.gif) |
Posted: Tue Jan 11, 2011 6:34 am |
One says S1 at the end and the other says P0... i think
![Razz Razz](images/smiles/icon_razz.gif)
Without checking, if they are both listed on the same thing eg drivers right arm.
Then one is for a 22" blade and the other is a 26" blade.
You want the latest/biggest RPO/DAM number as that will be 22"
Posted: Tue Jan 11, 2011 6:37 am |
So Iv got to go for 6429S1 then?
Posted: Tue Jan 11, 2011 6:38 am |
Yeah.
Just checked and thats the part number you want [SINCE RPO No. 08470]
Posted: Tue Jan 11, 2011 6:39 am |
You got a price Lee?
Posted: Tue Jan 11, 2011 6:41 am |
Comes up at £62.02 including VAT
Posted: Tue Jan 11, 2011 6:43 am |
Thanks Lee. fingers crossed that solves the problem
Posted: Tue Jan 11, 2011 6:44 am |
What's the problem?
Posted: Tue Jan 11, 2011 6:48 am |
I had it last year and it has come back.
Right in my eye line where the hook is on the blade, about 2 inchs up from the base of the screen in a curve it misses the screen. I have tried the trick of putting a cable tie on the spring to pull it tighter, worked for a bit but not now. It has become dangerous to drive in the rain as the screen is not clearing right where that is.
Been told the arm has gone.
Posted: Tue Jan 11, 2011 6:54 am |
Yeah it probably is the arm thats gone then. Unless the wiper blades you are running are too big so they aren't going flush to the screen.
Posted: Tue Jan 11, 2011 6:56 am |
Iv got the Bosch Aeros 21" and they have been fine, I have even swapped the blades over and it still happens
Posted: Tue Jan 11, 2011 6:57 am |
Must be the arm then like you said.
Posted: Tue Jan 11, 2011 6:59 am |
Cant see it being anything else to be honest
