Posted: Wed Jan 05, 2011 5:08 pm |
help needed, will a gti backobx, fit a 1.1?
Posted: Wed Jan 05, 2011 6:16 pm |
More than likely
Posted: Wed Jan 05, 2011 7:18 pm |
It won't run well with it on if you get it on..
| 206 GTI
Nimrods
SP Grille
Cargo Net!
Team: Old school member since May 2006 - 3k posts lost
Leader Team: Tivoli GTI
Leader Team: Cargo Net
Snowboard & Bindings For Sale
www.goneboarding.co.uk...ified.aspx | |
Posted: Thu Jan 06, 2011 1:33 am |
Trade Rating: +45
It wont be a direct fit it will need a bit of a modification. Why wouldnt it.run very well?
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
Posted: Thu Jan 06, 2011 11:33 am |
The bore is bigger connecting to the centre pipe so it won't fit properly and the fumes will be let out. Will need to be welded on and have extra material covering the gap.
Posted: Fri Jan 07, 2011 4:27 am |
Trade Rating: +45
So aslong as you get it properly fitted so tht the exhaust is sealed thwn it will alm be fine
Posted: Tue Jan 11, 2011 1:42 pm |
Backpressure?
| 206 GTI
Nimrods
SP Grille
Cargo Net!
Posted: Tue Jan 11, 2011 1:57 pm |
Pointless fitting one.
