Latest: SA01
Overall: 17138
Online Now [244]:
Visitors: 243
Today: 36374
Total: 111282820
Forums › The Car › 206 Problems › Front Seat Belt Sticks
wardyworld
PostPosted: Tue Jan 11, 2011 8:10 am Up
Hi,
My other half's 206 HDi Dturbo 3-Door (52 Plate) has developed a fault...
The drivers side front seat belt is not freely pulling out, it stops every inch or so and you have to gently pull it, release it, pull it, release it, etc. in order to get it out enough to put it on.
I think we need to get a new seat belt - are there multiple types, and if so - what do I need?
Am I right that I just need a Drivers Side front seat belt WITH pre-tentioner?
Cheers guys!
Ad Smile
206 GTi HDi
PostPosted: Tue Jan 11, 2011 8:52 am Up
You could try dis-mantling the seat belt and greasing it up to try and free it.
If you have seat belt pretentioners, you'll need a multiplexed one. And make sure they are unfired.
wardyworld
PostPosted: Tue Jan 11, 2011 9:43 am Up
Great - I thought so, cheers for the clarification. I think I will take it apart and try and grease it first.
Thanks Lee Very Happy
206 GTi HDi
PostPosted: Tue Jan 11, 2011 11:01 am Up
The non plexed / multiplexed thing doesnt matter with the seatbelt pretensioners Wink
It only the airbags that are different
PostPosted: Tue Jan 11, 2011 11:02 am Up
Not a good idea to take seatbelts apart unless you know what your doing.
As well as a very strong spring you also have the explosive pretension in there.
Just replace the seatbelt.
PostPosted: Tue Jan 11, 2011 11:05 am Up
Wasn't sure if they used different connectors or not, so just said to get a mux one to be on the safe side.
Think Jared has some seat belts for sale [pugJH]
PostPosted: Tue Jan 11, 2011 11:08 am Up
Its just a little 2 pin connector plug, they only have one explosive charge in Laughing
wardyworld
PostPosted: Wed Jan 12, 2011 7:44 am Up
OK - I'll get a new seat belt from a breakers.
Am I right then that there are only 2 types of front seat belt for a 3 Door 206?
With Pretensioner and Without Pretensioner?
Obviously I need a WITH Pretensioner if thats the case!
Cheers,
Ad. Smile
206 GTi HDi
PostPosted: Wed Jan 12, 2011 9:14 am Up
Yeah thats right
PostPosted: Wed Jan 12, 2011 11:27 am Up
All UK spec 206's will have pretensioners.
Get one for a NON accident damaged car, also get the matching buckle attached to the seat.
wardyworld
PostPosted: Wed Jan 12, 2011 12:28 pm Up
So Multiplexed / Non-Multiplexed it doesnt matter, just get the seatbelt and matching buckle - got you, cheers. There is a V reg 206 in the local scrap yard, will go and check this out.
Thanks,
Ad.
206 GTi HDi
