Online Now [169]:
Visitors: 169
Today: 29276
Total: 127714304
Forums › The Car › 206 Problems › Temperature needle not working...
Mike_XS
PostPosted: Wed Jan 12, 2011 10:38 am Up
I recently changed my dials for lockwood ones, when I put it back together everything works fine apart from the temp gauge.
It does the normal thing at start up where the lights come on and the needle goes up half way, but then it shoots off the scale and drops down to 140ish.
Does anyone know what I've done? When I get time I'm gonna take the cluster apart again and see if moving it up then down sorts it...
davieboy86
PostPosted: Wed Jan 12, 2011 10:44 am Up
Mine were the same when I changed dials, to fix it I tool the dial off let the engine get cold, then put the key in, turn the ignition on but don't start just make the other needles move then put the broken one back set at zero.
Did the same with mine and my petrol dial, for that I filled the petrol to the brim then put the needles on, may not be exact to the mm but best you can do yourself.
Hopefully that made sense lol.
PostPosted: Wed Jan 12, 2011 11:31 am Up
I take it you mean the oil level & temp gauge on the right?
It sounds like you haven't put that needle back in the correct place.
Mike_XS
PostPosted: Wed Jan 12, 2011 11:55 am Up
Yeah, the one on the right. I didn't take any of the needles off. Before I put it all back together i set them all to the off position.
PostPosted: Wed Jan 12, 2011 11:58 am Up
That gauge will shoot up for a few seconds to show the oil level then it should drop down to show the oil temp.
Gonna be trial & error tweaking the needle back in to the right position.
Mike_XS
PostPosted: Wed Jan 12, 2011 12:01 pm Up
Ah right, didn't realise thats why it shoots up. It does that as normal, but then shoots up a second time off the scale and then drops down to around 140. Then as the temp of the oil goes up the needle goes up from there.
PostPosted: Wed Jan 12, 2011 12:05 pm Up
The gauge should rise a tiny amount when the ignition is switched on.
Then it should shoot up to show the oil level for a few seconds
The it drops down to show the oil temp.
I reckon you have zeroed the needle in the wrong place Wink
It sounds like it needs moving down a bit, keep tweaking it down & then turn the ignition on to see where it goes to before it shoots up.
Mike_XS
PostPosted: Wed Jan 12, 2011 12:07 pm Up
How do I tweak it down? While I have the ignition on at the needle is up?
PostPosted: Wed Jan 12, 2011 12:10 pm Up
Gently move the needle downwards.
Does it sit on the rest pin with the ignition off?
Mike_XS
Yup
PostPosted: Wed Jan 12, 2011 12:16 pm Up
Just keep tweaking it down with the ignition on till it reads about right.
If the engine is stone cold the gauge should be reading around the bottom lines.
You could get really anal & ask the local mot place nicely to stick there oil temp probe down the dipstick tube with the engine nice & hot then tweak the needle so it reads correctly.
Mike_XS
PostPosted: Wed Jan 12, 2011 12:19 pm Up
I'll give it a go tweaking it myself tomorrow. We don't have any MOT garages over here...lol
Mike_XS
PostPosted: Thu Jan 13, 2011 7:41 am Up
Got it done, thanks for the help guys Smile
