Latest: slaapkonijn
Overall: 17169
Online Now [134]:
Visitors: 133
Today: 11243
Total: 128676956
Forums › The Car › 206 Problems › Slight problem
Slight problem
dan_206
PostPosted: Wed Jan 12, 2011 1:23 pm Up
Evening all,
Not usually one to post up about problems but basically was driving back from shop earlier and noticed a slight drone/knocking/rubbing noise. This only happens when the car is in gear and my foot is off the clutch and accelerator. Nothing when in neutral or when clutch is depressed, or I slightly put foot on accelerator. Bit vague I know but can anyone shed a light on what it could be?
Also you can't hear it from the outside when driving past.
Cheers
macj
PostPosted: Wed Jan 12, 2011 1:30 pm Up
Is it worse on either lock
dan_206
PostPosted: Wed Jan 12, 2011 1:38 pm Up
Nah same no matter what, straight line, hard right or hard left.
4th 206 but finally a 180
dan_206
PostPosted: Sun Jan 16, 2011 2:26 pm Up
Turns out it's the differential on it's way Sad
giveitsomebar
PostPosted: Sun Jan 16, 2011 2:28 pm Up
change the gearbox oil see if there's any metal in there. i thought the diffs in these are quite strong
dan_206
PostPosted: Sun Jan 16, 2011 2:35 pm Up
Nah not sure if it's in gearbox though as jacked the car up with engine off out of gear and spun wheel. Pretty sure it's the diff as it was still clicking.
macj
PostPosted: Sun Jan 16, 2011 3:37 pm Up
I got a spare GTi diff if you need one
dan_206
PostPosted: Sun Jan 16, 2011 3:47 pm Up
Would it fit a with a 1.4 gearbox though? Thought they were different?
