Latest: Beduff1977
Overall: 17134
Online Now [191]:
Visitors: 190
Today: 42998
Total: 107223861
Forums › The Car › 206 Problems › Few problems i need help with. MOT end of month!
frenchfrog40
PostPosted: Mon Jan 10, 2011 12:38 pm Up
Hi,
Just a few things i need to sort before MOT on 31st.
A) One of my washer jets isnt working and never has... apart from when i put a pin in it, then it "worked" for a couple of weeks and gave up again. i bought some new ones today but havent fitted them. Hopefully that sorts that problem out.
B) One of my number plate lights has gone... again... any tips on getting the bulb holder off as i remember it being quite hard last time.
C) One of my wiper blades fell off in the snow and then did it again last night, the guy at halfords said the clip may be broken, should i just get new wipers?
D) Last but not least, My reverse lights havent worked for about 10 months. I got some new bulbs and swapped them over and they still arent working. What fuse is it i need to change, what do i change it for and where is it? Razz
Think thats all i need to do...
Thanks. Chris
Iv had:
Rob2859
PostPosted: Mon Jan 10, 2011 12:44 pm Up
frenchfrog40 wrote:
Hi,
Thanks. Chris
A. plugit in should be fine
B. remove the cover from the inside of the tailgate (just pull) The clips for the bulbs need squeezing together and pusing out. (try usig two screwdrivers if its too stiff)
C. New wiper blade should sort you out
D. Yes check the fuse. Check in the box under the steering wheel. Can't remember which one but your handbook will tell you. Or just pul them out one at a time and check them
Abzynthe
PostPosted: Mon Jan 10, 2011 12:47 pm Up
East Area Rep - Abzynthe
you should be able to see which one is blown without taking em out shouldnt you?
in mine the little metal strips are on the top so you can see them.
PostPosted: Mon Jan 10, 2011 1:06 pm Up
D) Reverse lights aint mot testable items - it wont fail on these.
It will be the fuse or more likely the switch on the gearbox, unplug it & short the 2 connections out then turn the ignition on, see if the reverse lights work now.
Nellie
PostPosted: Mon Jan 10, 2011 1:11 pm Up
If you remove each fuse in turn you will eventually remove the radio one, which will probably mean the radio will ask for its code again, please be careful.
Neil C
PostPosted: Mon Jan 10, 2011 1:16 pm Up
GTI 180 is multiplexed, it wont ask for a radio code.
Removing fuses is still a bad idea as you can crash the BSI software / fry the BSI unit Laughing
Rob2859
PostPosted: Mon Jan 10, 2011 1:42 pm Up
unlikely. although thats why you do it with the bsi turned off Wink
PostPosted: Mon Jan 10, 2011 1:59 pm Up
Its even easier to find out the correct fuse number before you start work Wink
frenchfrog40
PostPosted: Mon Jan 10, 2011 2:12 pm Up
how do i get the correct fuse number? thanks for all the replies guys. will give some of these a go on thursday on my day off.
Iv had:
PostPosted: Mon Jan 10, 2011 2:13 pm Up
Fuse 4 and Fuse 21 in the drivers fusebox for the reverse lights
PostPosted: Mon Jan 10, 2011 2:14 pm Up
Have you fitted LED's to the reverse lights?
frenchfrog40
PostPosted: Mon Jan 10, 2011 2:28 pm Up
no, should i? i just bought normal bulbs.
Iv had:
PostPosted: Mon Jan 10, 2011 2:32 pm Up
Was just wondering, as they are polarised and they only fit one way.
frenchfrog40
PostPosted: Thu Jan 13, 2011 8:03 am Up
no, just standard bulbs.
Washer jets are now sorted and i found the fuse that has burnt out. its under the bonnet though in the big fuse box. Those red "fuse removing tweezers" that the book says to use to take them out are really really really rubbish, why do i need to use them?
Off to halfords now for a fuse and a number plate light.
Iv had:
frenchfrog40
PostPosted: Thu Jan 13, 2011 9:25 am Up
reverse lights are working again, was the fuse. got some number plate lights now just need to put them in.
Iv had:
