Online Now [236]:
Visitors: 235
Today: 64718
Total: 127884872
Forums › The Car › 206 Problems › Dashboard display
Dashboard display
abs06
PostPosted: Fri Jan 14, 2011 4:16 am Up
Hi everyone
Sorry if this has already been posted. Yesterday my dashboard display went off. I can make out the display but its very faint and u have to go up close. I think it may be the light.
My questions are:
1. Can i replace jus the bulbs or do i need a new unit?
2. How do i get to the unit to get it out?
Any help would be good.
Sorry if this has been posted before. Did do a quick search but didnt see any similar.
My car is a multiplex and the display is the bigger of the 3.
Thank you
Abs
Peugeot 206 1.6 Sport (55)
Audi A1 2.0 TDi Sport (14)
PostPosted: Fri Jan 14, 2011 4:19 am Up
It will be a case of changing the bulbs.
abs06
PostPosted: Fri Jan 14, 2011 4:21 am Up
Any ideas on how to get the unit out?
Abs
PostPosted: Fri Jan 14, 2011 4:28 am Up
Follow the first part of this guide about pulling off the hazzard surround.
206info.co.uk/Forums/v...=3072.html
Then there are 2 or 4 torx screws holding it in place.
abs06
PostPosted: Fri Jan 14, 2011 4:31 am Up
Wicked. Fank u. Will get to it now Smile
Abs
PostPosted: Fri Jan 14, 2011 4:32 am Up
If you can still see the display, you sure you haven't turned the brightness down by accident?
Bassline_Toad
PostPosted: Fri Jan 14, 2011 4:42 am Up
If you're taking it off anyway, it might be worth just pushing the bulbs around a bit. Mine were loose causing a bad connection, meaning it was really dark. No need to buy new bulbs if thats the case Smile
abs06
PostPosted: Fri Jan 14, 2011 4:54 am Up
I though i had turned the lights on dash down. But the rest of dash is like a christmas tree. I think it is bulb because when i got my car, one corner was dim.
Abs
abs06
PostPosted: Fri Jan 14, 2011 5:02 am Up
Well that was wierd. All fixed
Took of the surround. And the black front panel an ot light up again Very Happy might be a lose
Connection. Happy days
Abs
ExoVyper
PostPosted: Fri Jan 14, 2011 5:05 am Up
i had this with my one.
just a bad connection with the bulbs Razz
the amount of times i just hit the hazard light surround to shake them into working xD
