Latest: tbafonso
Overall: 17130
Online Now [243]:
Visitors: 241
Members: 1
Today: 10517
Total: 104135310
Forums › The Car › 206 Talk › A bit short notice but anyone free to fit some suspension?
drunknmunky
PostPosted: Fri Jan 14, 2011 2:30 pm Up
Anyone local to me with the tools and know how wanna fit my suspension for me? willing to pay of course Smile
would like it done tomorrow if possible and you would need to bring the right tools for the job
Other option is anyone know a good garage thats open weekends that will do it for me must be pretty local once again?
Thanks Smile
T_bandery
PostPosted: Fri Jan 14, 2011 2:33 pm Up
DIY
p**s easy lol
PostPosted: Fri Jan 14, 2011 2:38 pm Up
It's easy if you know how. It's very easy to get so far and realise you don't have all the right tools etc for the job.
drunknmunky
PostPosted: Fri Jan 14, 2011 2:41 pm Up
i have some tools and everything and was gonna do it but i have totally give up on it now im drained from working on the car all day today and everything im doing on it seems to take forever
would be a lot easier with a proper garage to do it in im sure Smile
kieron
PostPosted: Fri Jan 14, 2011 6:18 pm Up
buy a cheap socket set and do it yourself you will just need spring clamps and depending how how you go you will need them to put them back on
rear is easy as long as its not seized up if not a big slegd hammer can help with a little heat
good look
Account suspended
