Posted: Sun Jan 16, 2011 3:08 pm |
Can you turn off economy mode and automatic lights?
Economy mode is realy starting to p-ss me off!
Posted: Sun Jan 16, 2011 3:12 pm |
Trade Rating: +36
To turn off auto light keep your finger on the button of the indicator switch, Eco mode Im not sure about.
Posted: Sun Jan 16, 2011 3:16 pm |
does it beep or indicate it has done it? i have done this b for but doesnt seem 2 do anything. hm..... will give it a go tomorow.
Posted: Sun Jan 16, 2011 3:31 pm |
Eco mode is a BSI state which only occurs if the battery is getting low. It's designed so that you don't drain the battery to a point where you can't start the car.
If it's occurring quickly, you may want to check your battery.
Posted: Sun Jan 16, 2011 3:40 pm |
To turn off auto lights, put the ignition on, hold the button on the end of the light stalk until you hear a "bong" noise come from around the steering wheel area.
The only solution ive found to eco mode is to start and stop the engine to get past it...
Posted: Sun Jan 16, 2011 3:51 pm |
Trade Rating: +36
Yeah sorry mate forgot to say put the ignition on but pug206lx covered it.
Posted: Sun Jan 16, 2011 4:01 pm |
Trade Rating: +45
The only way tht o can think of turning off eco mode is by going to pug and seeing if they can do it
| PAST -2008 Vauxhall Astra VXR / 2002 pug 206 GTI
Now have my 106 GTI track car
TEAM - I HATE FACEBOOK  | |
Posted: Sun Jan 16, 2011 4:40 pm |
meady wrote: |
The only way tht o can think of turning off eco mode is by going to pug and seeing if they can do it |
Why would you bother though... It's like you want to not be able to start your car!?
Posted: Sun Jan 16, 2011 4:43 pm |
Ash wrote: |
meady wrote: |
Why would you bother though... It's like you want to not be able to start your car!? |
It's a safety precaution. ECO mode is enabled, when there is enough charge left in the battery for one start of the car. Would you rather be stranded with a flat battery?
Posted: Sun Jan 16, 2011 5:04 pm |
Lee wrote: |
Ash wrote: |
meady wrote: |
It's a safety precaution. ECO mode is enabled, when there is enough charge left in the battery for one start of the car. Would you rather be stranded with a flat battery? |
i am pretty sure the radio doesnt use much battery, and mine kicks in after 15 mins no matter how high or low my batter charge is. i used to have a fiesta and i could run the radio with the internal light on for hours and it would start no problem. all im saying is there is no need in it coming on so early. maby after an hour or more then yes but it realy does just take the mikky. i should be telling the car what i want it to do, not what it it allowes me to do.
Posted: Sun Jan 16, 2011 5:13 pm |
thats odd i as run my radio when ever i clean and polish my car for about 2 hours fine an eco mode dont kick in get your battery checked mate that could be your problem
regards
Posted: Sun Jan 16, 2011 5:17 pm |
wifey wrote: |
regards |
Are you non-plexed?
Posted: Sun Jan 16, 2011 5:29 pm |
Trade Rating: +45
Im not saying tht i would turn it off. I think its a gd thing, im jus saying thts the only way i can think of turning it off
Posted: Sun Jan 16, 2011 5:33 pm |
Lee wrote: |
wifey wrote: |
regards |
Are you non-plexed? |
no multi
Posted: Mon Jan 17, 2011 5:03 am |
pnut_man wrote: |
Lee wrote: |
Ash wrote: |
meady wrote: |
i am pretty sure the radio doesnt use much battery, and mine kicks in after 15 mins no matter how high or low my batter charge is. i used to have a fiesta and i could run the radio with the internal light on for hours and it would start no problem. all im saying is there is no need in it coming on so early. maby after an hour or more then yes but it realy does just take the mikky. i should be telling the car what i want it to do, not what it it allowes me to do. |
Go pay your local Peugeot dealer to disable it in your BSI configuration set up then
