Posted: Tue Jan 18, 2011 5:37 pm |
hi
i have just bought a gti and the hight adjustment don't work on the drivers side,
is there a fix for this or even just a way to get it to the lowest setting and keep it there??
thanks
Nic
| Thanks\r\nNic\r\nwww.prideandperformance.co.uk | |
Posted: Tue Jan 18, 2011 5:38 pm |
Whats not actually working on the height adjustor?
Normally you sit on the seat, pull the handle up, seat will drop down & back then let go of the handle & the seat should stay there.
Posted: Tue Jan 18, 2011 5:40 pm |
the handle don't feel right when you pull it and you can pull it and then jump up and down ant it won't move?
Posted: Wed Jan 19, 2011 4:17 am |
ahh no mate i had this happen on my passenger side you could move it to let people in but you couldnt adjust the tilt luckily it was covered under warranty but i have no idea what caused it but i think it might only of come of something or there a 2p stuck or somethin lol
Posted: Wed Jan 19, 2011 5:06 am |
Does the adjustment lever feel very loose? Mine came back from the dealer with a loose adjuster after it had been in for something completely different.
If you take the seat out, you should be able to see a loose pin that is normally welded in place on the side of the seat frame. If you have a welder, you should be able to push the pin back in it's normal place and weld it in place. If you don't have a welder, like me, you can use a 40mm long mate bolt. Measure the length of the thicker part of the original pin and cut a length of aluminium pipe to act as a shim. then push that into place, nut at the end and it should work again.
Posted: Wed Jan 19, 2011 6:09 am |
matcarlin24 wrote: |
ahh no mate i had this happen on my passenger side you could move it to let people in but you couldnt adjust the tilt luckily it was covered under warranty but i have no idea what caused it but i think it might only of come of something or there a 2p stuck or somethin lol |
You're talking about something completely different.
| China Blue 2.0 HDi DTurbo
-Sports Bumpers -Rear Spoiler -Rear Lexus Lights -SP Fuel Cap -SP Bonnet Vent -SP Upper Grille -SP Lower Grille (Zunsport) -Crystals | |
Posted: Wed Jan 19, 2011 7:11 am |
Twidly wrote: |
You're talking about something completely different.  |
ALRIGHT jesus i'm just saying I had a similar problem but on the passenger seat it was stuck in a posistion and i couldn't adjust it and the handle would be fine to let people in but adjustin the tilt it was like the handle was stuck. I was just making a point that it's most probably something stupid like easily fixed!!!!!!! So just read what i said instead of trying to be the ultimate knowledge I know how much of a wounder it is so I was trying to HELP
Posted: Wed Jan 19, 2011 2:48 pm |
thanks guys,
quit the domestics though lol
i have sorted it, i just pulled it with all my might and jumped up and down and it started to come free,
no it is working fine
brute force and ignorance sometimes is the best way,
Posted: Wed Jan 19, 2011 3:23 pm |
Twidly wrote: |
ALRIGHT jesus i'm just saying I had a similar problem but on the passenger seat it was stuck in a posistion and i couldn't adjust it and the handle would be fine to let people in but adjustin the tilt it was like the handle was stuck. I was just making a point that it's most probably something stupid like easily fixed!!!!!!! So just read what i said instead of trying to be the ultimate knowledge I know how much of a wounder it is so I was trying to HELP |
You're still talking about the wrong handle.
He's on about the one to the front and left of the drivers seat... makes the seat go up & down, not tilt.
Posted: Wed Jan 19, 2011 3:38 pm |
My seat works fine. Just saying.
Posted: Wed Jan 19, 2011 3:39 pm |
Ash wrote: |
My seat works fine. Just saying. |
Yeah mine too
Posted: Wed Jan 19, 2011 3:40 pm |
Twidly wrote: |
Ash wrote: |
Yeah mine too  |
Life is good henneh
Posted: Wed Jan 19, 2011 4:06 pm |
as we talking seats lol, anyone else find putting there seat belt on a pain in the a**e?
mine always catches between the seat tilt thingy and the door!
Posted: Wed Jan 19, 2011 4:15 pm |
stevedude wrote: |
mine always catches between the seat tilt thingy and the door! |
Yeah but that's cause my belt has part twisted behind the rear doorcards and doesn't retract as it should. Gunna sort it this weekend
Posted: Thu Jan 20, 2011 11:45 am |
stevedude wrote: |
yes this is a pain,
i used to get annoyed with it in hannah's quicksilver and now my gti does the same thing
is it just the sport seats that this happens with or all the seats?
