Latest: tbafonso
Overall: 17130
Online Now [53]:
Visitors: 52
Today: 38925
Total: 104508981
Forums › The Car › 206 Talk › Fuel pump symptoms
Fuel pump symptoms
Kersh
PostPosted: Thu Jan 20, 2011 3:01 am Up
how do you know if your fuel pump is underperforming?
my accelerator needs a little blip to make the car start 90 percent of the time.
when i change gear the revs seem to rise slightly still while the clutch is down.
before i start the car and turn the key so that the fuel pump kicks in, instead of the standard whirring noise it clicks as well.
what does all this mean?
help is appreciated Smile
Joe
Member number: 36
Kersh
PostPosted: Thu Jan 20, 2011 10:46 am Up
bump?
Member number: 36
imjeeves
PostPosted: Thu Jan 20, 2011 11:31 am Up
You need to attach a fuel pressure guage into your line to test it. Should have 3bar of pressure in the line
