Posted: Thu Jan 20, 2011 8:20 am |
Hey,
I've searched through the posts the best I could so sorry if i am repeating a prior post!
The speedometer on the dash all works fine but when i switch my lights on the backlight doesn't come on, this makes driving at night a 'mare as i cant see how fast im going!!
Has anybody else had this issue? I think it may be a fuse but have no idea which one, I'm going to buy a Haynes manual at the weekend but until then any ideas? The glovebox light is also not working
Car is a 2000 Hdi 2.0
Thanks!
Posted: Thu Jan 20, 2011 8:27 am |
Sounds like a fuse, have a look at the fuses under the steering wheel. If any have popped replace them
good luck
| You never really learn to swear until you learn to drive | |
Posted: Thu Jan 20, 2011 9:33 am |
will check tonight,
cheers!
Posted: Thu Jan 20, 2011 9:47 am |
Just had a look and I dont have the manual at hand, does anybody know which fuse it is?
Really need this Haynes manual at the weekend!!
Posted: Thu Jan 20, 2011 1:32 pm |
check this: fuse is there anything else not working other than that?
| el camino. "Whether you think you can or you think you can't, you're right" Henry Ford. | |
Posted: Thu Jan 20, 2011 1:36 pm |
cig lighter, centre console lights and glove box light
Posted: Thu Jan 20, 2011 1:41 pm |
Pls. check if your number plate and side lights fine?
Posted: Thu Jan 20, 2011 1:43 pm |
yep those all work fine
thanks
Posted: Thu Jan 20, 2011 1:47 pm |
Ok.what about fuse?i think u should chk. no. 22
Posted: Thu Jan 20, 2011 1:49 pm |
will do,
thanks for the advice, what order does the fuses count top left to top right and then down a row?
Posted: Fri Jan 21, 2011 11:49 am |
anybody?! or a pic of the fuse layout from the manual would be uber appreciated!
Posted: Fri Jan 21, 2011 1:36 pm |
Numbers are written.but its better to check all the fuses.although i think its not a melted fuse....
Posted: Sat Jan 22, 2011 4:16 am |
cheers will check them all, bought a load of spares this morning
Posted: Sat Jan 22, 2011 4:51 am |
that sounds like fuse f15 or f20 one or the other (inthink) but it will probably vary
Posted: Thu Jan 27, 2011 10:13 am |
Okay i changed the fuses in F22 and looked at all the others, and they are fine, but nothing has been restored!
things that are not working (that i have noticed) are:
Speedometer back light
number plate lights (only just noticed that was out after checking everything)
panel below the stereo - all buttons have no back light
glove box light.
could it be possible all the bulbs have gone?
