Latest: Beduff1977
Overall: 17134
Online Now [563]:
Visitors: 562
Today: 45886
Total: 107981189
Forums › The Car › 206 Problems › cambelt change documentation
robertmarcs
PostPosted: Wed Jan 12, 2011 7:06 am Up
basically guys i need the help of someone who works at a peugeot dealership. i need the documentation off peugeot service (not servicebox) for changing the timing kit. i can get the docs for the 2l petrol picasso engine which as far as i know is the same as the 206 gti. but i want to get the right docs to be sure!
if anyone can help please gimme a pm
thanks
Cool
PostPosted: Wed Jan 12, 2011 8:41 am Up
PostPosted: Wed Jan 12, 2011 10:52 am Up
I knew that only "Lee" is gonna answer this topic Very Happy
Danw_VVT
PostPosted: Wed Jan 12, 2011 10:56 am Up
goes without saying lol
PostPosted: Wed Jan 12, 2011 12:03 pm Up
Don't forget about the possibility of struggling to get the belt covers off with the engine still on its mounts. ECU also needs to be removed so you'll have to remove the security bolts.
RallyGTI
PostPosted: Sun Jan 23, 2011 12:11 pm Up
I have managed to get the front and middle bolts out of the belt cover. How do you get the rear bolt out. I have removed the ECU but not the top engine mount. Do you drop or raise the engine?
Please advise.
Thanks in advance
GTI is ready
RallyGTI
PostPosted: Tue Feb 15, 2011 2:00 pm Up
bump Any help???
GTI is ready
