Online Now [193]:
Visitors: 192
Today: 5469
Total: 104978493
Forums › The Car › 206 Talk › Part No wanted
Part No wanted
paulrushton
PostPosted: Sun Jan 23, 2011 4:29 am Up
Hi
Is there anybody who can confirm the part number for a fuel cap sensor for a 2004 1.6hdi. Also is it the same part number from a 1.4hdi? I'm trying to give me more options for finding a replacement.
Paul
Peugeot 206 GTI HDI Black
PostPosted: Sun Jan 23, 2011 5:23 am Up
Fuel cap sensor??
paulrushton
PostPosted: Sun Jan 23, 2011 6:50 am Up
Yeah it's linked to the FAP system. There's a sensor which is located behind the fuel cap up inside the rear wheel arch. The sensor has wiring that runs to the fuel pump under the back seat.
The sensor tells the car that the fuel caps off and puts s shot if Eolys into the tank. Sometimes one of the two magnets drops off the fuel cap itself but in my case theyre present and the sensors died. Pug want £55.53+vat for one.
PostPosted: Sun Jan 23, 2011 7:32 am Up
Get your wallet out then & order one Wink
PostPosted: Sun Jan 23, 2011 7:44 am Up
If you're 100% that's the problem then I'd just get a new one.
paulrushton
PostPosted: Sun Jan 23, 2011 8:56 am Up
It brought up fault code P2048 which is directly that part. I'll be ordering one Monday in any case but was living in hope...
