Posted: Sat Jan 22, 2011 11:01 am |
Newly charged battery fitted, I now have no alarm LED and the key fob does not work..... Any suggestions... Cheers
| | ![](images/spacer.gif) |
Posted: Sat Jan 22, 2011 11:02 am |
Do a search - there is a reprogramming sequence to follow but it is specific to your car (age and model)
Posted: Sat Jan 22, 2011 11:05 am |
![](http://img.photobucket.com/albums/v201/PowerLee/Crystalball.jpg~original)
Give us some clues
Non plexed or multiplexed 206?
If it was plexed did you shut down / boot the BSI up correctly?
Posted: Sat Jan 22, 2011 11:10 am |
2003 GLX.... Plexed Non-Plexed???? Have found reprogramming site but I have no LED
Posted: Sat Jan 22, 2011 11:12 am |
Your 206 is MULTIPLEXED
Start the engine
Press & hold the UNLOCK button on the key fob for 10 seconds.
Hope you shut down / booted the BSI up correctly as that can stop things like remote locking working ![Wink Wink](images/smiles/icon_wink.gif)
Read this for info on the BSI & how to disconnect / reconnect the battery correctly
www.206info.co.uk/Foru...tboot.html
Posted: Sat Jan 22, 2011 11:28 am |
Cheers, it's given me a starting point.... Could be back though
Posted: Sat Jan 22, 2011 11:35 am |
Shut down then reboot the BSI correctly & see if that improves things.
Posted: Sun Jan 23, 2011 7:36 am |
All sorted, great advice thanks
Posted: Sun Jan 23, 2011 7:38 am |
Does your alarm arm only on the deadlocks? ( one press )
OR
Does it also arm on normal locking? ( two presses )
Red alarm led come on & stay on if the doors are locked with engine running?
Posted: Sun Jan 23, 2011 12:00 pm |
Alarm arms with first press, no indicator flash on second press. LED flashes when car is armed... No LED if door lock button is pressed when engine is running
Posted: Sun Jan 23, 2011 12:52 pm |
Keebs wrote: |
Alarm arms with first press, no indicator flash on second press. LED flashes when car is armed... No LED if door lock button is pressed when engine is running |
Old / pre December 2007 BSI software version then ![Wink Wink](images/smiles/icon_wink.gif)
