Online Now [523]:
Visitors: 522
Today: 78576
Total: 145041018
Forums › The Car › 206 Problems › 206 seat
206 seat
ki789
PostPosted: Tue Jan 25, 2011 6:02 pm Up
hi i bought a seat, was ment to be out of a 3 door like mine but it does not quite work the same for example...
when u pull the handle on my seat it flips forward and the whole seat moves forward with it allowing access to the back but ...
the seat i brought flips forward but the whole seat don't move , so it's quite hard for people to squeeze in ,anyone know if it's because it's a 5 door seat or because it's a older version of mine ?
PostPosted: Tue Jan 25, 2011 6:04 pm Up
i think is the problem of the slider
ki789
PostPosted: Tue Jan 25, 2011 6:05 pm Up
also the seat is bigger than mine and rubs against my doors and middle of the car
PostPosted: Tue Jan 25, 2011 7:36 pm Up
Is it a GTI Seat? Sit in it, and try and move the seat back and forth with the seat adjuster under the front. Somtimes they stick.
PostPosted: Tue Jan 25, 2011 7:46 pm Up
can you post the pic of the seat?
PostPosted: Wed Jan 26, 2011 12:01 pm Up
Look at the tilt handle on the side of the seat.
The 3 door & 5 door seat handles are different Wink
The 3 door handle should have a picture of tilt with an arrow pointing backwards & also another picture of tilt & slide with the arrow pointing forwards Wink
5 door seats only have the picture of tilt with backwards facing arrow.
NOTE: This also depends on if someones ever previously changed the seat handle & fitted the wrong one Laughing
