Latest: cogeim7
Overall: 17185
Online Now [819]:
Visitors: 818
Today: 121701
Total: 147420187
Forums › The Car › 206 Talk › paint
paint
Forum Index › 206 Talk
PostPosted: Tue Jan 25, 2011 4:17 pm Up
ok, will need to paint the rollcage myself as can't powder coating it (weld-in cage)
thinking about matt black/ satin black.
what kind of paint do i need? btw i am using paintbrush as i can't be bother to spray it.
stevedude
PostPosted: Tue Jan 25, 2011 4:24 pm Up
use enamel, its good enough for mountain bikes
Happydays
Dillon
PostPosted: Tue Jan 25, 2011 4:29 pm Up
Staff - Dillon
I was going to say hammerite if your using a brush finish should look ok.
PostPosted: Tue Jan 25, 2011 4:40 pm Up
do i need to use primer first?
it said no need to use primer on the tin but i will just ask in case...
and how many layers do i need? would 1 layer be enough?
PostPosted: Tue Jan 25, 2011 4:43 pm Up
is that the brand name?
sorry i don't know much about paint Embarassed
PostPosted: Tue Jan 25, 2011 4:45 pm Up
I guess enamel is the type of paint to use and if you do use hammerite you won't need primer as you can paint it straight onto rust for sure.
stevedude
if ya gonna use hammer, ya will need to do a couple of coats, BUT it will have to be recoated in 3 hours, or it could look like ya fingers look like after being in bath too long!
use spray enamel, so easy, and give a nice glossy coat lol, it comes in orange too
Happydays
PostPosted: Tue Jan 25, 2011 4:46 pm Up
Just use Hammerite direct to rust one, you shouldn't need primer.
stevedude
PostPosted: Tue Jan 25, 2011 4:47 pm Up
no its a type of paint, pop to halfords they have loads.
if not got ya colour look online, will need priming first thou, but thats not hard
Happydays
PostPosted: Tue Jan 25, 2011 4:48 pm Up
ok that sounds sweat, i might just stick with hammerite then as i think halford do stock them?
PostPosted: Tue Jan 25, 2011 4:51 pm Up
do i have to use thinner with hammerite?
PostPosted: Tue Jan 25, 2011 4:53 pm Up
Nah, just straight out of the pot Smile
About a fiver, for the last pot i bought
PostPosted: Tue Jan 25, 2011 4:54 pm Up
Halfords do stock them yes, around £7-8 for a smaller tin. What do you mean about thinners? It would be wise to clean the surface before painting yes.
PostPosted: Tue Jan 25, 2011 4:56 pm Up
like to dilute the paint before using it
PostPosted: Tue Jan 25, 2011 4:57 pm Up
nice! Razz
