Online Now [276]:
Visitors: 275
Today: 80103
Total: 142792368
Forums › The Car › 206 Talk › Gearbox oil
Gearbox oil
smccullie
PostPosted: Wed Jan 26, 2011 12:06 pm Up
Where do you fill up your gearbox oil on a 206 1.4 t reg, I can see a drain but no filler plug??
thanks
206 1.4 t reg
PostPosted: Wed Jan 26, 2011 12:08 pm Up
They're usually on the side, you have to remove the passenger arch lining IIRC.
Or there will be a breather on the top. If you know the exact amount to fill it with you can fill it through there.
PostPosted: Wed Jan 26, 2011 1:03 pm Up
make sure you use 75w/80 oil
smccullie
PostPosted: Wed Jan 26, 2011 1:37 pm Up
Thanks for that, I got told to use engine oil
206 1.4 t reg
eddrj
PostPosted: Wed Jan 26, 2011 1:53 pm Up
there is a how to ... change gearbox oil on here with pics , and shows pic of correct oil ul need for the gearbox
Old car 2000/ 206 2.0 hdi.
PostPosted: Wed Jan 26, 2011 1:58 pm Up
Peugeot / Citroen part number 9736 41 Gear oil 2 litre £13.54
smccullie
PostPosted: Wed Jan 26, 2011 2:00 pm Up
Thanks will have a read of that, I got some zx1 to put in as well. Done a engine oil service today with some zx1 added, what a difference sounds alot smoother
206 1.4 t reg
PostPosted: Wed Jan 26, 2011 2:03 pm Up
Don't put any of that ZX1 additive crap in a MA gearbox Wink
The MA box is VERY picky on oil Wink
smccullie
PostPosted: Wed Jan 26, 2011 2:07 pm Up
Ok a no no with the zx1, Think the correct oil in the box might help, I know the person that had it before used engine oil in it
206 1.4 t reg
PostPosted: Wed Jan 26, 2011 2:09 pm Up
Ive already posted the part number in this thread for the correct oil Wink
Pop along to your local Peugeot / Citroen dealer & visit the parts desk Laughing
PostPosted: Wed Jan 26, 2011 2:20 pm Up
no wonder why people's gearbox can pop lol
PostPosted: Wed Jan 26, 2011 2:23 pm Up
Never listen to that person ever again.
PostPosted: Wed Jan 26, 2011 2:25 pm Up
To be fair, a few gearboxes do use engine oil Wink
That's why you should always check the handbook OR ask the manufacturer what lubricant you should use.
smccullie
PostPosted: Wed Jan 26, 2011 2:32 pm Up
If i remember tomorrow i will take some pics, sort of how to using the breather insted of under the car method
206 1.4 t reg
PostPosted: Wed Jan 26, 2011 2:34 pm Up
As long as you don't overfill the gearbox it will be fine.
