Latest: Stu-mill
Overall: 17131
Online Now [311]:
Visitors: 310
Today: 57994
Total: 104743580
Forums › The Car › 206 Talk › fitted tune box engine light on wont go off
eddrj
PostPosted: Fri Jan 28, 2011 10:08 am Up
Hi i just fitted tuning box and engine light wont go off even when ive put back other old connector in any ideas ? taken box off still light on
Old car 2000/ 206 2.0 hdi.
Kersh
PostPosted: Fri Jan 28, 2011 10:19 am Up
probably something else, maybe the extra power from the box caused something to go?
Member number: 36
PostPosted: Fri Jan 28, 2011 10:21 am Up
It says about this in the manual that you get with the tuning box, it should give you a warning!
It is the 'anti-pollution fault', its due to the new readings that the ecu has to learn thru the increased fueling. It should go off after a week or so of driving. You could try connecting the tuning box, and disconnecting the battery to reset the ECU to default, to see if that makes it go off any quicker.
Bailey
PostPosted: Fri Jan 28, 2011 10:29 am Up
Not a solution... but have you noticed much difference in the power? cheers
eddrj
the orange light is the engine mangement though isnt it ? so you r saying its safe to drive you think ?
PostPosted: Fri Jan 28, 2011 10:31 am Up
Yes its safe to drive
eddrj
PostPosted: Fri Jan 28, 2011 11:00 am Up
ok isnt is fail mot engine light on ??
PostPosted: Fri Jan 28, 2011 11:02 am Up
yes
Rob2859
PostPosted: Fri Jan 28, 2011 11:03 am Up
put a bit of tape over it Very Happy
PostPosted: Fri Jan 28, 2011 11:06 am Up
Seabook wrote:
yes
Really?
Mines gone thru 2 MOTs with the light on before
and the rents has gone thru about 10 with the light on Laughing
Lee180
PostPosted: Fri Jan 28, 2011 11:12 am Up
engine management light can go through depending on why its on ,i think, dont quote Smile
Originate, don't duplicate.
PostPosted: Fri Jan 28, 2011 11:13 am Up
Nope, not unless it fails the emissions test.
eddrj
PostPosted: Fri Jan 28, 2011 11:19 am Up
ok thats alrit then long as dont fail mot , tell you what well happy with it really is like another car much faster and more fun to drive ,not fussed about light as drives good and quick and wont fail mot
PostPosted: Fri Jan 28, 2011 11:20 am Up
It WILL fail next year as the mot test is changing slightly & becoming a lot more tougher Wink
eddrj
PostPosted: Fri Jan 28, 2011 11:23 am Up
fitted box again now because light on no matter what now , mot not due till about june but how would i get it off then took box off light still on same so may aswell use it now but really cant get that light off
