Online Now [564]:
Visitors: 563
Today: 78128
Total: 145188433
Forums › The Car › 206 Problems › starting problem
starting problem
saiefovech
PostPosted: Sat Jan 29, 2011 12:15 pm Up
hello all ,,, i bought a new key cover for my 206 GTI and i just changed the electronic component from the old one to the new key cover ,, and suddenly when i wanted to switch on the car it does not start it just tell me engine immobilizer fault .. so whats the problem with it ?? and when i use the spare key for the car it works .... so please advice me
PostPosted: Sat Jan 29, 2011 12:21 pm Up
Look inside your old keyfob, there will be a small black chip inside.
Without that transponder chip the car wont start Wink
saiefovech
PostPosted: Sat Jan 29, 2011 12:23 pm Up
can u explain to me where is it exactly ??
PostPosted: Sat Jan 29, 2011 12:24 pm Up
Its a small black chip inside the keyfob, its NOT part of the electrical circuit board.
Open the old fob up & you should see it.
saiefovech
PostPosted: Sat Jan 29, 2011 1:07 pm Up
i found it .. thanks a lot i really appreciate your help
PostPosted: Sat Jan 29, 2011 1:12 pm Up
Swop it over in to your new key & problem sorted.
