Latest: jackrox1992
Overall: 17186
Online Now [935]:
Visitors: 934
Today: 249861
Total: 147947912
Forums › The Car › 206 Problems › idle control valve
idle control valve
kirsty1978
PostPosted: Sun Jan 30, 2011 10:18 am Up
not being thick but does a hdi have an idle control valve? because my needle on the rev counter moves up and down slightly when in netural and i have noticed that it goes up quickly for a second then comes back down
206 hdi
PostPosted: Sun Jan 30, 2011 10:35 am Up
No, its ECU controlled.
The idle will flutter if things such as the AC is on.
elcamino
PostPosted: Sun Jan 30, 2011 10:40 am Up
I'd check the stepper motor mate.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
PostPosted: Sun Jan 30, 2011 10:43 am Up
Doesn't have one.
kirsty1978
PostPosted: Sun Jan 30, 2011 10:45 am Up
no ac on, i put some redex in the diesel didnt make any difference
206 hdi
PostPosted: Sun Jan 30, 2011 10:48 am Up
Shouldn't use redex, as once you use it, you need to keep using it. Should use premium fuel instead.
How much does it flutter up and down?
You recently had the battery off?
kirsty1978
PostPosted: Sun Jan 30, 2011 11:03 am Up
it almost sounds like its purring lol battery not been off
206 hdi
Ben.M
PostPosted: Sun Jan 30, 2011 11:04 am Up
Just out of curiosity, why??? Razz
Ben.M
elcamino
PostPosted: Sun Jan 30, 2011 11:23 am Up
Lee wrote:
Doesn't have one.
Sorry thought it does..
