Forums › The Car › 206 Problems › could anyone help me locate the fan wiring relay? |
Posted: Tue Feb 01, 2011 1:55 pm |
i need help finding the fan wiring relay as i think it needs replacing... anyone know where it is and how i go about replacing it?? help?
| Smoothed & Clean or Nothing at all | |
Posted: Tue Feb 01, 2011 2:38 pm |
It right at the front of the car behind the grille. It's behind a removable panel.
You can see the panel here to the left of the fan.
