Latest: jackrox1992
Overall: 17186
Online Now [642]:
Visitors: 642
Today: 135469
Total: 148287776
Forums › The Car › 206 Problems › heater matrix
heater matrix
solly
PostPosted: Thu Feb 03, 2011 12:39 pm Up
hi
i need some help. my matrix heater is leaking into the passenger footwell. i need to get it replaced but have been getting ridiculous quotes. someone said i have to remove the whole dash. is that true? also has anyone done it and can offer me any advice?
307 BLACK
PostPosted: Thu Feb 03, 2011 12:40 pm Up
You can get it out without removing the whole dash.
You need to remove the glove box compartment (glovebox door and inside lining). Once the lining is out, you can bend the dash trim that runs under the glovebox out of the way to slide the heater matrix in and out. It will easily bend once the glovebox liner is out and it will return to its original condition once you let go. Much easier than spending a day getting the dash out.
www.peugeotcentral.co....amp;t=1592
www.206info.co.uk/Foru...atrix.html
solly
this is for a 206 1.4 verve 2006
307 BLACK
Liam-HuTcH
PostPosted: Thu Feb 03, 2011 1:12 pm Up
East Area Rep - Liam-HuTcH
very easy to replace done one previously on a 1998 plate and was completed in little over an hour. Dash removal isn't required.
Team: Smashed Up Firedance
Team: Black 206
elcamino
PostPosted: Thu Feb 03, 2011 4:21 pm Up
Before you remove the heater matrix check the o rings first.there is a disconnect with two o rings where the pipes coming from engine are connected to the matrix.
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
solly
PostPosted: Fri Feb 04, 2011 10:34 am Up
hi
i have taken out the glovebox compartment. where is the actual heater matrix?
307 BLACK
Liam-HuTcH
PostPosted: Fri Feb 04, 2011 10:35 am Up
to the right hand side behind the dash,
Team: Black 206
Liam-HuTcH
PostPosted: Fri Feb 04, 2011 10:38 am Up
found a how too if you need it
www.peugeot206cc.co.uk...hg2gf3.htm
Team: Black 206
