Latest: cogeim7
Overall: 17185
Online Now [606]:
Visitors: 605
Today: 192952
Total: 147091292
Forums › The Car › 206 Problems › Air Condition.
Air Condition.
egouder
PostPosted: Sat Feb 05, 2011 7:31 am Up
I read somewhere that it is important to at least turn on your a/c at least once a month for 10 minutes! Since we are currently in winter i dont use it very often but yesterday i switch it on! And the car just seem to rev by its self!!! it was very bugging!!! even the idling revs were higher!!! and when i shift gear the car automatically revs even tho i'm obviously not applying gas between gears!!!
The A/c was serviced few months ago
My father has a 306 1.9diesel, at when his ac is on the revs keep normal!
is this a problem i should be concerned about?
thanks
PostPosted: Sat Feb 05, 2011 7:39 am Up
It's normal for the revs to be higher when AC is on
egouder
PostPosted: Sat Feb 05, 2011 7:42 am Up
thanks lee!
but they are very noticeable....though i should ask since i never saw a car behave this way.
Dabamash
PostPosted: Sat Feb 05, 2011 7:45 am Up
Staff - Daba
Mine revs up slightly when the AC is first put on. It's probably just because it hasn't been on in a while
brad-morris
PostPosted: Sat Feb 05, 2011 8:28 am Up
i normally use my Air conditioning its not just for use in the cold, it conditions the air so you use it when you car has excess condensation.
