Posted: Wed Feb 09, 2011 1:45 pm |
basicly my girlfriend has a 2000 ford puma 1.7 we have just had a new water pump fitted once fitted heaters work fine now the car has sat over night there is no hot air comming from the heaters
any help will be appricated thanks
Posted: Wed Feb 09, 2011 1:47 pm |
air lock?
Any work you undertake as a result of my posts is done so at your own risk  | |
Posted: Wed Feb 09, 2011 1:49 pm |
Air lock or the heater control valve has packed in.
Does your interior light work?
If the fuse goes for the light the HCV gets no power and won't work
Sam.
Posted: Wed Feb 09, 2011 1:55 pm |
try running the engine with the coolant top off until the cooling fans kick in, if u hav no heaters now, u may hav a faulty heater control valve witch is in bulkhead
Posted: Wed Feb 09, 2011 1:57 pm |
Heater matrix.
It went on my old ZS and it's probably the same for this as they are made out of plastic iirc.
Posted: Wed Feb 09, 2011 2:00 pm |
coincidence that it happens the day after a new water pump was fitted?
Posted: Wed Feb 09, 2011 2:34 pm |
If it was working before the pump was replaced I reckon air lock.
Posted: Wed Feb 09, 2011 4:47 pm |
charlie-52 wrote: |
any help will be appricated thanks  |
If you just had the water pump changed why dont you take it back to where you had the work done??????????
| 206 Gti 180 Cat-camshafts 804's, Cat cams CTPE 002 exhaust vernier pully, RS tuning remap, Cat back janspeed exhaust, K@N Typhoon induction kit- heat wrapped, Exhaust manifold heat wrapped, Goodridge brake flexi's poly bushs in rear lateral arms, blue led speedo convertion, 50mm Eibach sport line springs, ......
180 Doctor
Hemwoods Gti180 / Pug specialist | |
