Posted: Wed Feb 09, 2011 3:31 pm |
any one knows where can i get a pugkey with transponer cheap? (2 buttom phase 1 key)
and get them cut and code as well?
Posted: Wed Feb 09, 2011 3:34 pm |
try www.hickleys.com/diagn...02&manu=28
someone local to you with pp2000 could do it if you have the key card available. if you have a normal serated blade then any key cutter would do the blade for you.
| Former owner of a 1.4 HDi for six years | |
Posted: Wed Feb 09, 2011 3:35 pm |
Found out the other day I can code the key to the car.
A key shop might be able to cut the keys
You got the 4 digit security code and the mechanical key number? If you haven't tell me your VIN number
Posted: Wed Feb 09, 2011 3:37 pm |
echo?
Posted: Wed Feb 09, 2011 3:38 pm |
| Lee wrote: |
http://www.hickleys.com/diagnostics/keys_list.php?cat=102&manu=28
You got the 4 digit security code and the mechanical key number? If you haven't tell me your VIN number  |
you can code the key? excellent. how much do you charge? and do you know how to code the keyfob as well?
i got the security code. but i don't think i have got the mechanical key number
I had a blade cut today in a high street key shop, they cut it from the image of the original and its able to operate all the locks on a mechanical basis. Got the blade off ebay for a few quid.
Posted: Wed Feb 09, 2011 3:39 pm |
You code all the transponders at once to the immobilser when you've unlocked it with the security code
I'd just do it for the usual £20, maybe a tad more if you need me to come to Leeds, for the fuel cost.
I'd code read it, and turn any settings on at the same time while im there
Posted: Wed Feb 09, 2011 3:42 pm |
| Lee wrote: |
I'd code read it, and turn any settings on at the same time while im there  |
will pm you later once i get the keys and chips
Posted: Wed Feb 09, 2011 3:49 pm |
Sound
Posted: Wed Feb 09, 2011 3:57 pm |
do i need the new chip or can i get the used one from ebay?
Posted: Wed Feb 09, 2011 4:03 pm |
No, the transponder chip from one car can't be reprogrammed to another car
Posted: Wed Feb 09, 2011 4:07 pm |
| Lee wrote: |
| No, the transponder chip from one car can't be reprogrammed to another car |
i can't find the the key fob that i used to have in your link
it looks like this
cgi.ebay.co.uk/2-BUTTO...5ade8762c7
Posted: Wed Feb 09, 2011 4:16 pm |
it said 6552ZX from service box :s
Posted: Wed Feb 09, 2011 4:40 pm |
Not sure if all the transponder chips come with the 2 buttons, because I know mine has the two buttons on the circuit board but not on the fob.
Just ring them up and ask to see what they say.
Posted: Wed Feb 09, 2011 5:04 pm |
ok will do
