Posted: Wed Feb 09, 2011 5:38 am |
As soon as i pull off in my car after first starting up and taking the handbrake off the handbrake light comes on, i have noticed a lot of brake dust build up on the rear alloy (driver side) after most journeys 10 miles+, is the handbrake rubbing maybe? there isn't any noise
| 206 GTI, Ram air filter, lowered 35mm front, 50mm rear, Scorpion 3.5" Back box, phase 2 boot strip, m3 rear lights.. Not much more i want to do, just sorting the paint work out! | |
Posted: Wed Feb 09, 2011 5:52 am |
maybe low fluid, maybe due to low brakes??
some cars have low brake warning light unsure if the 206 has one (i know lower ends dosnt)
Posted: Wed Feb 09, 2011 6:01 am |
Checked my brake level and its all fine
Posted: Wed Feb 09, 2011 6:06 am |
this gets covered most weeks, take the console from round the handbrake and there will be a switch under there check that is all plugged in
Posted: Wed Feb 09, 2011 6:10 am |
Nice one, will check when i get home, thanks
Posted: Wed Feb 09, 2011 6:19 am |
The light flashes when the pads are low as well... Also check them.
| Hi Mikey
Posted: Wed Feb 09, 2011 6:21 am |
Good point too, due for a service! Cheers guys
