Online Now [186]:
Visitors: 185
Today: 17421
Total: 138639361
Forums › The Car › 206 Talk › 206 cup cars
206 cup cars
giveitsomebar
PostPosted: Tue Feb 08, 2011 7:43 pm Up
does anyone know the top spec of these which you could buy from peugeot ? im building a road rally car and anything on a cup car i can use so i need every bit of spec from body work inside and out to headlights!
Cheers
imjeeves
PostPosted: Wed Feb 09, 2011 3:21 am Up
There is a specific spec yes. It is detailed on Peugeot Sport France website if you look that up. There are group N, group A and RC spec cars. They are all based on price so your budget will determine what you can build.
I wouldnt advise doing the way you are as you will still pay around £30,000 to build a 206 cup in bits from Pug Sport.
You would be far better to buy an alrady bult cup car which are selling from around £5500 to £8000
giveitsomebar
PostPosted: Wed Feb 09, 2011 5:52 am Up
thanks for that jeeves i didnt explain what i was doing properly im building a gti with a 180 engine in it but for road rallys as long as peugeot produced a car with stuff on it as standard i can use them bits like carbon door cards, discharge lights , the same throttle body if i was using a 1600 engine that sort of stuff
imjeeves
PostPosted: Wed Feb 09, 2011 5:59 am Up
Ah ok. Yeh well I would just follow what the cup cars do as the RC or 180 parts are a lot more expensive to buy. The bodywork is very much standard unless you decide to go for a full group A bodykit. This is a big step as all the subframe, bottom arms etc need to be modified in order to accomidate it which is a bit much for road rallying.
The cup cars modification usually include:
doorcards, suspension, sumpguard, all the engine mods which you wont do if you have a 180, exhaust, rear beam solid mounts.
Try www.specialtuninguk.co.uk/ for parts in the UK and an idea of prices but I find Peugeot sport France is cheaper.
giveitsomebar
just found this could help someone else out if they are doing the same as me
www.specialtuninguk.co...20Book.pdf
giveitsomebar
PostPosted: Wed Feb 09, 2011 6:01 am Up
just found that website just before you posted that reply i doubt i will use group a body panels it was more the interior carbon door cars and the headlights i was praying they made them with discharge head lights but it doesnt look like they do Sad
thanks for all your help jeeves
PostPosted: Wed Feb 09, 2011 7:47 am Up
never order parts from specialtuning, they are robbers. order them directly from pug sport are at least 30% cheaper. delivery are spot on as well.
giveitsomebar
PostPosted: Wed Feb 09, 2011 7:49 am Up
cool i looked on pug sport and it didnt really say much about 206 bits it just showed 207 bits, on special tuning i didnt think they were to bad door cards were about £140-150 each including tax sounds promising if peugeot sport can get them cheaper!
PostPosted: Wed Feb 09, 2011 7:53 am Up
price on specialtuning are all ex. VAT Laughing Laughing
you probably need to scroll through all the 206 tabs on the pugsport website as the website is not very organized
imjeeves
Not so sure that is always true seabook as some parts have a marginal difference and then when you add french tax and postage there is not much in it.
There is a guy on ebay sells carbon door cards for around £120 a pair. Seems like a better deal than £130 a side!
imjeeves
PostPosted: Wed Feb 09, 2011 7:57 am Up
Peugeot France does have all the 206 parts but there is an easy way to get into it. Will post it later on if someone else doesnt post the link up.
PostPosted: Wed Feb 09, 2011 7:59 am Up
all of the stuff (wishbone, wheel bolts, torsion bar) i ordered in the past from pugsport are at least 30% cheaper than specialtuning (if not more). some parts might have smaller difference but i doubt specialtuning will be cheaper anyway.
french tax is lower than UK's vat Laughing
and normally pugsport don't charge much on delivery too Cool (no ideal about large items such as bodykit etc...)
PostPosted: Wed Feb 09, 2011 8:00 am Up
i saw that ebay door cards too.
but the pugsport one is a lot nicer Embarassed Embarassed
PostPosted: Wed Feb 09, 2011 8:02 am Up
www.peugeotsport-racin...px?nom=206
this one?
imjeeves
PostPosted: Wed Feb 09, 2011 8:07 am Up
I made my own ones and then cut the tops off a standard doorcard and painted them black. Look just as good as any of the Pug Sport ones and cost a lot less.
I do think they are a must
