Latest: sparrowdclxvi
Overall: 17139
Online Now [73]:
Visitors: 72
Today: 1145
Total: 112476655
Forums › The Car › 206 Problems › stop light
stop light
206racer
PostPosted: Thu Feb 10, 2011 2:19 pm Up
just had cambelt,water pump and oil and filter changed on girlfriends car.We have been out in it(i was driving)when the stop light flashed once.Is this because of the work been carried out or is there another problem?Should i go and get it read for any codes?
51 reg 1.1
hello
PostPosted: Thu Feb 10, 2011 2:22 pm Up
Take it back to the garage where you had the work done, ASAP
206racer
PostPosted: Thu Feb 10, 2011 2:26 pm Up
One qustion does the stop light come on if the fuel light comes on?
hello
PostPosted: Thu Feb 10, 2011 2:27 pm Up
No it shouldn't
206racer
PostPosted: Thu Feb 10, 2011 2:29 pm Up
Just that the fuel light came on and beeped then the stop light flashed once
hello
matt.handley
PostPosted: Thu Feb 10, 2011 3:02 pm Up
What He Said
206racer
PostPosted: Thu Feb 10, 2011 3:15 pm Up
The car runs fine.i have been and filled up with petrol and done 20 miles with no light.Will take it back and let them read for a code.
hello
PostPosted: Thu Feb 10, 2011 3:28 pm Up
Would the garage have taken the battery off to do the work?
206racer
PostPosted: Thu Feb 10, 2011 3:31 pm Up
Possible was done on tuesday and light only came on today.
hello
elcamino
PostPosted: Thu Feb 10, 2011 3:37 pm Up
Have you checked brake fluid level?and does stop light come with hand brake: (!) light?
el camino. "Whether you think you can or you think you can't, you're right" Henry Ford.
dopey
Thread hijack sorry, I know this sounds stupid, but when I turn my key in my ignition and start the engine the engine management and stop light are on but go straight off, and my car runs fine. Does this happen on every 206? sorry if I sound thick.
206racer
PostPosted: Thu Feb 10, 2011 3:38 pm Up
The light only flashed once and has not been on since.
hello
elcamino
PostPosted: Thu Feb 10, 2011 3:44 pm Up
It is normal when engine turned on and everything is ok all lights go off.but depending on software version stop light wont come on on some 206's.but engine amber light must come on before start.
dopey
PostPosted: Thu Feb 10, 2011 3:49 pm Up
Ok that's good I have been worrying for month's Lol.
giveitsomebar
PostPosted: Thu Feb 10, 2011 6:20 pm Up
check the oil level it could be low an surged as you went round a corner if that looks ok then do as above get it back to the garage asap
