Posted: Fri Feb 11, 2011 11:34 am |
Hi,
Got myself ph2 washers (actualy waiting on the drivers side to come in) and I am looking to fit.
How is it done?
Its hard to tell because from my bump that ripped it off, there is only a small piece of plastic still connected to the tubing. Pair of pliars to pull it out and shove the new one in?
Just wanted to check before I star tearing things up.
Jordan
Posted: Fri Feb 11, 2011 11:36 am |
Just holds on with a clip on the bottom of the jet and connect the tubing to it... Very easy task
Posted: Fri Feb 11, 2011 11:38 am |
You might want to fit a small tie-rap around the end of the tubing where the jet joins it, as it may have stretched and so may leak.
Posted: Fri Feb 11, 2011 11:41 am |
water out of the kettle to soak the old washer piping in if its proving difficult to disconnect from the washer jet
Posted: Fri Feb 11, 2011 12:15 pm |
Got it out. Easy.
Cheers boys.
