Posted: Sat Feb 12, 2011 3:27 pm |
Hi,
the brother in law is goign to service my 2002 206 GTi and i need to buy all the parts for him, so i need:
Spark Plugs
Pollen Filter
Oil Filter
Sump Plug Washer
Fuel Filter???
Oil - What grade to use and brand?
Can anyone recoomend any specific ones? i.e. Bosch Super 4 Spark Plugs?
Washer part number?
Anything i've missed?
Posted: Sat Feb 12, 2011 3:28 pm |
Air filter? K&n would be ideal as theyre only like £25 from ebay I think.
Posted: Sat Feb 12, 2011 3:31 pm |
Air filter is already K&N, sorry i forgot to mention that so just cleaning it
Posted: Sat Feb 12, 2011 3:44 pm |
10w40 oil mobil is what me and howey use and it's really good
Bosch super 4 spark plugs
Most likely won't need a fuel filter as they are in the fuel tank and don't need to be changed
Don't forget get the sump plug as well as the washer.
| Moonstone blue 206 1.4look
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
TEAM: I'm a greedy jelly fiend! | |
Posted: Sat Feb 12, 2011 3:59 pm |
Are you not supposed to use 5w40 oil in a GTi?.
You don't have to replace the sump plug, as long as you don't damage it when you remove it.
Good shout on the Bosch Super 4's, I can vouch for these.
| Jun 09 - Nov 09: Peugeot 106 1.1 Independence
Nov 09 - January 10: Vauxhall Astra 1.6 8v Club
January 10 - June 10: Peugeot 206 1.4 GLX
June 10 - Present: Peugeot 206 2.0 GTi | |
Posted: Sat Feb 12, 2011 4:04 pm |
I'd be interested to know what oil i should use - don't want to use the wrong thing
Posted: Sat Feb 12, 2011 4:06 pm |
Well it depends on the mileage of the car, the higher the mileage the thicker the oil (such as 10w40) should be because of engine wear, and therefore need the thicker oil.
If it's low mileage the thinner 5w40 will be better
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Sat Feb 12, 2011 4:08 pm |
10w/40 and 5w/40 has the same thickness when warm up....
Posted: Sat Feb 12, 2011 4:14 pm |
Seabook wrote: |
10w/40 and 5w/40 has the same thickness when warm up.... |
90% of engine wear occurs before the engine is up to temperature, so thicker oil is going to better for worn engines
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Sat Feb 12, 2011 4:16 pm |
mileage is about 80,000 at the minute
Posted: Sat Feb 12, 2011 4:17 pm |
A18NHH wrote: |
mileage is about 80,000 at the minute  |
I would recommend the 10w40 then
pro race 1.2 White
Morettes
GTI wings
TEAM: Carbon Fibre
Posted: Sat Feb 12, 2011 4:24 pm |
Mrs_Howey wrote: |
Seabook wrote: |
90% of engine wear occurs before the engine is up to temperature, so thicker oil is going to better for worn engines |
or thinner oil to give faster oil circulation to prevent start-up wear?
not mean to mess around but it seems that every people said different thing when come down to the choice of engine oil
Posted: Sat Feb 12, 2011 4:26 pm |
lol - i'll buy the oil last then and try and find out a little bit more
Posted: Sat Feb 12, 2011 4:34 pm |
Get in touch with 'Oilman'. He was really helpful.
Posted: Sat Feb 12, 2011 4:36 pm |
roberto.f wrote: |
Get in touch with 'Oilman'. He was really helpful. |
but his oil is quite expensive
