Latest: sparrowdclxvi
Overall: 17139
Online Now [97]:
Visitors: 96
Today: 10714
Total: 113251208
Forums › The Car › 206 Problems › indicator stalk end button switch should it do any thing?
danny206glx
PostPosted: Sun Feb 13, 2011 7:12 am Up
i bought my 206 1.4 glx 03 plate in november. there is a button switch on the end of my idicator stalk which does nothing but pushes in as should do something. is it broken or does it not do any thing? please help
PostPosted: Sun Feb 13, 2011 7:17 am Up
Computer?
PostPosted: Sun Feb 13, 2011 7:18 am Up
E5GDM wrote:
Computer?
no thats on the right stalk.
I think the one on the left is for auto lights or something?
Matt wrote:
This is normal. They are follow me home lights and stay on for 30 secs or until you lock the car. To turn on/off turn key 2 clicks then press and hold button one ends of left stalk.
danny206glx
PostPosted: Sun Feb 13, 2011 7:29 am Up
my right stalk has the same button but does not push in it is solid. but the left satlk does push in but nothing happens.
danny206glx
PostPosted: Sun Feb 13, 2011 7:33 am Up
i tried the turning the key and holding the button but didnt do any thing :S
PostPosted: Sun Feb 13, 2011 7:37 am Up
The COM2000 may have been replaced with one with more functions than your BSI has activated Wink
PostPosted: Sun Feb 13, 2011 7:52 am Up
DJ- wrote:
E5GDM wrote:
Computer?
If you have auto wipers then you may have auto lights. Turn the key to position 1 and hold the button for more than four seconds. You should hear a tone and see a message saying auto lights active. To de-activate, just repeat the process.
The follow me home lights are activated by turning the key to 0 and then flashing your main beam. Just leave the car as normal. The lights should then stay on for about 60 seconds. To turn them off just over ride them by turning your lights back on.
danny206glx
PostPosted: Sun Feb 13, 2011 7:53 am Up
but all the automatic lights and every thing else work on it. i wonderd if it was to change a display on the center consol?
danny206glx
PostPosted: Sun Feb 13, 2011 7:55 am Up
macca1411 wrote:
DJ- wrote:
E5GDM wrote:
Computer?
yes i do have auto lights and ok ill try it
danny206glx
PostPosted: Sun Feb 13, 2011 8:02 am Up
danny206glx wrote:
macca1411 wrote:
DJ- wrote:
E5GDM wrote:
Computer?
tried it it did beep after four seconds but the display didnt say auto lights active and they didnt stay on for any time. should i have the lights on auto, side lights or dipped?
PostPosted: Sun Feb 13, 2011 8:04 am Up
Its a GLX so it has auto lights fitted.
The button on the end of the headlamp stalk is to turn the auto lights feature on & off UNLESS its been disabled in the BSI configuration set up.
As for the follow me home headlights there activation depends on the BSI software version the car is running Wink
PostPosted: Sun Feb 13, 2011 8:05 am Up
It wont say auto lights active as you have the smaller display Wink
Leave the light switch set to AUTO.
Start the engine & cover the sensor with you hand for a good few seconds Wink
danny206glx
PostPosted: Sun Feb 13, 2011 8:10 am Up
my auto lights are on the twist bit on the stalk not the button :S
PostPosted: Sun Feb 13, 2011 8:11 am Up
Leave the twist bit set at AUTO Wink
danny206glx
PostPosted: Sun Feb 13, 2011 8:12 am Up
i dont get what that has to do with the button my auto lights are fully functional :S
