Online Now [1350]:
Visitors: 1349
Today: 20238
Total: 149099596
Forums › The Car › 206 Problems › 180 - Loud ticking noise
Lee180
PostPosted: Mon Feb 14, 2011 6:46 pm Up
so, as titled, there is a very loud ticking noise ( almost sounds diesel ), atleast there was for about 20 minutes after i took the 180 for a lap around the local '' track ''. as you can image, fast gear shifts, high revs, ect ect ect. then almost asif by magic it stopped ticking loudly.
( the track is a privately owned run way, by a friend whos parents run a parashooting experiance )
my first impressions - cam belt ?
any ideas guys ?
thanks in advance
Originate, don't duplicate.
PostPosted: Mon Feb 14, 2011 6:49 pm Up
hydraulic tappers.
did it only happen when cold start and only at idle speed?
Lee180
PostPosted: Mon Feb 14, 2011 6:53 pm Up
nope, it was after i kained it down the runway, then kept the car running and pulled up, it was still doing it when it was moving. its stopped now, car seems fine.
Ali_H
PostPosted: Mon Feb 14, 2011 7:27 pm Up
Do you let it warm up before ragging it?
kurtis wrote:
Lee180
PostPosted: Tue Feb 15, 2011 1:35 am Up
yeah it was warmed up, had been driving it for about a hour before
Lee.
PostPosted: Tue Feb 15, 2011 3:26 am Up
The exhaust cooling down? Mine makes a loud tick when the exhaust starts to cool!
Lee180
PostPosted: Tue Feb 15, 2011 3:39 am Up
This was coming from engin bay mate, sounded like cam belt ticking
MrrNoName
PostPosted: Tue Feb 15, 2011 4:08 am Up
mine does this too. its like "tick tick tick tick tick" then suddenly stops, have no idea whats causing it Razz
PostPosted: Tue Feb 15, 2011 4:10 am Up
On yours it will most likely be the small brown valve hidden under the bonnet behind the left hand end of the engine near the inlet manifold, directly in front of the driver, its pretty well hidden.
MrrNoName
PostPosted: Tue Feb 15, 2011 4:22 am Up
whats it do?
PostPosted: Tue Feb 15, 2011 4:26 am Up
MrrNoName wrote:
whats it do?
Something to do with the emissions system, there cheap enough to replace if it is the cause of your problems.
Big_Rich180
PostPosted: Tue Feb 15, 2011 4:53 am Up
Any oil in it???
MrrNoName
PostPosted: Tue Feb 15, 2011 7:00 am Up
oil in it?
you mean the car? yeh shes just below the max line, has been since teh oil change. doesnt use a drop Smile
Lee180
PostPosted: Tue Feb 15, 2011 11:08 am Up
MrrNoName Wink Talk about thread hi-jacking Wink
MrrNoName
PostPosted: Tue Feb 15, 2011 11:46 am Up
sorry dude Wink
back to your tick, where on the engine is it comming from Razz
